Saw those, I wanted something more dedicated thoughEven Topdon makes some that are $200 - $250, I thought about trying the ones you plug into your phone
Whale shitThey warp and cause all sorts of odd issues. Little critters can get in there and wreck havoc as well.
I'll play with the key later,I wonder if is the electronic portion of the key switch in the column? Try bumping the keys while its running.
I just pulled a 9.5 rear end apart from a burb for one of my projects. I was thinking about your burb when I took all the rust free parts out of it. Was around 100k or less when I got it and been sitting under a tarp for years since i have had it. I had to pull the retaining rings on the wheel studs to get the disk off it. Never been apart before.
What you going to do with that?I'll play with the key later,
I've got a 10.50 14B FF to go in the back of it or my 75 K20.
Did score a whole harness ECM pedal for a 03-07 LQ4/4L85/4*4 for 150.00 last week as well
I believe the LB7/LLY is the same 03-05 Gasser pedal.Just like LB7/LLY to LBZ. Interesting.
Short immediate answer, was to strip MAF/CMP circuits out of it and repin them into the suburban, vs cutting a 6-8" pigtails and routine new wiresWhat you going to do with that?
BTW 03-05 is different from 06-07 and you need the matching TAC module for that pedal for the respective year range, other wise it goes into REP mode. I think the TB is the same. I don't recall. Fortunately they are not expensive.
yours bad?Short immediate answer, was to strip MAF/CMP circuits out of it and repin them into the suburban, vs cutting a 6-8" pigtails and routine new wires
