1,456
Had extra parts fall out on disassembly...
So much for easy fix...
Time for new hose
3,058
I believe it's just O ring, then plastic piece. When pushing the connector onto the radiator, the plastic piece will put pressure on the O ring. Or something like that
1,456
You are correct.
While I don't have PPE stuff..
Locally, I can get gates/dayco for ~220
Sent some money to DHD
1,862
Yeah I'm familiar with them, haven't convinced myself to drop ~800 on the proflow yet.
Good thing, all the bolts and important fittings are new and will easily come apart ?
The OEM 26gl is annoying, emailed Titan tank about their ECSB 37gl replacement tank, said they dropped it a short time ago, S&B stopped years ago, same with transfer flow.
There's still a few Titan ECSB tanks out there in the wild for ~1000.00
Saw this that looks like an old transfer flow tank, but he owner has no idea and a freebie with the Ford truck he bought.
Once I have a bed, I can drop a ~12D*16H*60L ~45gl tank or simiy in the front of the bed
There's always mounting a 25-30gl 80-90s Blazer tank in the spare tire area. I have couple C&C dual tank control modules from 90s C3500HD that I can run dual tanks and gauges.
Brakes are done... shocks, steering, gauges next, most likely in that order, do need cognito braces, have the TR sleeves.
This stock TC stall is definitely annoying, IDK how long that will stay there.. I do have my old AX7L TC still mounted in my old dually transmission. I'm not turning the HP up anymore till I have a built transmission
The DPC 3BLS is what I'm really after.
I personally am a big Goerend fan but also have used/am a dealer for DPC. DPC is a solid brand but not my typical "go to". I have not had a single failure that wasn't caused by something else like a torn seal, debris, low fluid etc. The DPC units seem to run 10-15f hotter than Goerend, this is comparing a "C" (stock LB7 stator triple disk) to a 3BLS. DPC's 3BLS is their version of a billet stator OEM stall converter.
Goerend G and X are similar to the 3BLS. They're targeted at the OEM LB7 stator stall speed but with some nice drivability bumps.
The G is simply a billet version of the C stator. The X is a harder coupling low stall converter that would likely fit your desires well IF you're not running a larger drop in turbo.
1,456
The 3BLS is closest I have found commonly advertised to the transtar AX7L that I ran in my LMM hotshot dually.
I'll be putting my GT4088R in, unless I pivot and put a 363/68 in
IMO stock is way too loose of a TC even for stock setup
I'm 20 miles from firepunk diesel which is a huge DPC vendor
1,617
1,456
I feel the same as Josh. Silicone coolant hoses have never ended well long term for me our my customers, they always tended to leak.
I will be interested to see what you think when they show up and you install them.
I hate silicone coolant hoses. They always seem to leak.
Well I'll let y'all know lol.
According to @TheBac coworkers, should make it from Harbor Beach Michigan to my area delivered by Friday
3,058
I've tried that and they still leaked. Too much tension and you exaggerate the rate of "squish", too little and you leak.
I wish you luck with them.
What if it was wrapped or has a wider band to spread the load or squish out, before putting the clamp on? I've had to do this for some hoses before to keep the clamp from cutting into the rubber. Use a metal tube/pipe. Cut it into a "C" and put the clamp over that.
1,456
I plan on clocking everything then putting a coat of Permatex Black Silicone Adhesive Sealant 81158 on every joint except the water pump while using similar constant tension clamps on the CAC pipe boots
