3,795
419
When I did my Duraburb in 2017 we couldn't find an easy spot for a fuel cooler, so I don't run one at all. Fuel temps are basically identical to my truck, even when the fuel light is on (fuel light takes 32 gallons to fill the 35 gallon tank).
I don't tow heavy with the Suburban, but I do tow a travel trailer and the occasional broken down truck behind it, never had a problem.
I suspect any fuel cooler you get on there is as good or better than the stock one, which IMO isn't even needed.
Sent from my CPH2655 using Tapatalk
1,514
I'm not too worried about a fuel cooler right now, especially heading into winter.
I've thought about picking up a banks I-dash to monitor fuel temps and other parameters.
I know my LMM dually would avg 180-190° while towing with no cooler
I forget at what temp the ECM derates for high fuel temp
lutzjk
1,926
378
groveport, ohio
I haven’t ran a cooler in 4 years or so? Mine started leaking while we’re in the middle of our move and I forgot about it until I read this. ?
1,514
Well sanded-ish cleaned the dirt off.. vac attachment doesn't pull all the dust up, but solid 75-80% of it..
1 24oz Rust-Oleum can does 95% of both sides,
It's 80° out so I should get couple coats on it. I have some gloss black I'll probably paint the bottom with.
So Adams cheap version of the old macco 200$ paint job?
1st coat
Also check tune, ECM starts pulling rail pressure from 180mpa at 230°F
3,571
Back when I was 17, I took my F-85 to Earl to get it painted after a very large amount of DIY bodywork. The color chart I picked my color from wasnt even close to the final color on the car, but for $49.95 (at the time), who was I to complain?
3,927
828
It wasn't the color of the week, gotta pay extra for what you really wanted :p
1,514
2nd coat of black is on, touched up black over spray and got white over spray??‍♂️?.
That RDS 60gl I picked up early this year,.. one of the 2" boss was plugged with a 2" PVC plug..got one of the nice units flow flow security came in today.
Start staycation on the 29th
Before the bed gets installed this gets installed.. some 1.5 dozen rivets need cut ...
Plus everything else I've bought gets installed
1,514
Took the 8/29-9/8 off so
Made some progress today
Really hate how rough this rides without the 1700lb block on the back..think I'll make a brick that I can set over the GN coupler then use the GN hitch to hold it in the bed.. probably 3'*4'*6".. 1 cubic foot of concrete ~140-145lbs
No one local stocks 6-12, 1-10 7 wire, so that projects waits till I order it.
Picked up fitting for the aux tank, need to get a 3/8" ball valve to shut it off.
It was 22 rivets needed to come out.. definitely appreciate 80gl air tank and long barrels air hammer lol
