Ron Nielson
930
234
Berryton, KS
What I haven't found, is how does the ECM get the request to crank?
Where/how does the switch send the request? Is it a momentary signal to the BCM then sent via data cables/can bus? Or wire straight to the ECM?
The BCM start messages via CanBus, not straight wire to the ECM, ECM checks to see if it's ok to run the starter (not in gear, etc). I have no idea within the BCM what happens but as long as you hold the key in START, the starter will run. To me that says it's continuous
1,514
Im basically trying to use the start circuit to figure out if the BCM is bad or not.
I found the #1020 circuit shortly before bed last night. Hopefully test it tonight
1,514
@Ron Nielson that's a much nicer picture of what I grossly pieced together. Going to verify the ignition switch is working and verify the BCM is being told something via the switch.
I have found that the RPM/MPH/FL/EOP/TFT/ECT info along with TH, CC all run through the BCM and none of that stuff works. And can't read codes
1,514
Why is Garret "running"? Is he personally delivering it?
Having this service provided
1,674
Oh.... hit the R instead of the T. oppsie...:LOL:
Make's a big differences... I was picturing Forrest Gump running with a BCM all the way to your house. :ROFLMAO: Run Forest, Run!!!!
1,514
Or maybe it was the Spell Check. Either way Forest is on his way in my mind...:ROFLMAO:
Spell check worked just fine, gramar kinda...
Burb, I bought new cam sensor, pig tail and intake gaskes, and problem went away.... So motivation to dig into it has diminished ??‍♂️
Also trying to save for a set of these for my wagon..
1,514
Nope, also been trying to help a guy do a engine swap on a 86 olds Cutlass 442 about 45 minutes away.. his eyes are bigger than his knowledge or pocket book is but has a willingness to learn
3,589
350? 455? Please, dear god, not another LS swap.....
1,514
Got the tracking number, BCM "should" be here by close of business Friday..
Also called dealer about new ignition cylinder and key. Current setup generally has to be jiggled to cycle from OFF. The doors, for the most part are fine.
I'm looking at ~250-300 for ignition cylinder, it being built and a fresh key cut to match.. add another 150 per door.... that's a project that can wait a bit
993
You probably just need a new key. You should be able to get a dealer to cut a new one from the key code that they can find using the VIN as long as you can provide proof of ownership.
