Shucks. I know the earlier models didn't care about vin. So, LMM is vin sensitive?From what I've found there vin specific stuff additional to VATs which I disabled with EFI live
IDK, just what I've found or been told..Shucks. I know the earlier models didn't care about vin. So, LMM is vin sensitive?
@lutzjk913 whatcha after
Close enough, this it is hanging downIs that your BCM?
That's the plan.. find the short.. hoping it will be screaming under the thermal scan.. supposed to hit 32° today. Guessing plastic starts smelling around 150-185°??I’d wait until you trace that short also. Did you see any voltage on the ground?
In the world of thermals.....~$400.00 is on the cheap side for thermalsJust had to go for the expensive model didn't ya
~300mA isn't a whole lot of current on a 16-18ga wireI use those on boats to look for small shorts. LEDs are becoming an issue, bc they don’t pull enough amps to pop a breaker of fuse when they short. Had one smoldering and still hadn’t broken the 2 amp fuse.
Even Topdon makes some that are $200 - $250, I thought about trying the ones you plug into your phoneIn the world of thermals.....~$400.00 is on the cheap side for thermals
Didn't feel comfortable with the HF AMES model line for $200.00
