1,456
Supposedly there's two main grounds under the dash, G200/G201, I haven't been able to find directions to where they are actually located under the dash..
Also might make some big body to frame cable grounds as mine didn't have any
3,058
Both should be on each A piller right below the top cover
036.6turbo
945
254
Vehicle Information
VIN: 1GCHK49639E134996Model: CK20753-2009 SILVERADO 2500 4WD EXT CAB
Service Contracts and Subscriptions: NoBranded Title: NoWarranty Block: NoPDI Status: Yes
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Vehicle Build
Model: CK20753 - 2009 SILVERADO 2500 4WD EXT CABOrder Number: NFPH6B
Gross Vehicle Weight: 4,177Build Date: 02/17/2009
Build Plant: E
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
1SZ - OPTION PKG DISCOUNT1WT - SILVERADO WT EQUIPMENT GROUP:
50U - SUMMIT WHITE6GL - FRONT SPRING
7GL - FRONT SPRING88B - DARK TITANIUM
88I - DARK TITANIUMA10 - FIXED RR SIDE WINDOW
AE7 - 40/20/40 SPLIT BENCH RECLINING FRONT SEATAJ1 - DEEP TINTED GLASS
AM1 - MANUAL LUMBAR, DRIVERAM7 - FOLDING REAR SEAT
BG9 - RUBBERIZED-VINYL FLOOR COVERINGC49 - ELECTRIC REAR WINDOW DEFOGGER
C67 - AIR CONDITIONING, MANUALC6W - GVW RATING - 9,200 LBS
C99 - IP SWITCHDE2 - BLACK FOLDAWAY EXTERIOR MIRRORS
DK8 - DELUXE OVERHEAD CONSOLEE63 - FLEETSIDE BODY
EF7 - U.S. COUNTRY CODEFT2 - ARM TORS BAR SPRING ADJ
FT3 - ARM TORS BAR SPRING ADJG80 - LOCKING REAR DIFFERENTIAL
GMC - ASSEMBLY PLANT-PONTIAC EASTGT4 - REAR AXLE - 3.73 RATIO
JH6 - 4 WHEEL POWER DISC BRAKES, HDJL1 - TRAILER BRAKE CONTROLLER
JL4 - STABILITRAK-STABILITY CONTROL W/ TRACTION CONTROL SYSTEMK05 - ENGINE BLOCK HEATER
K34 - CRUISE CONTROLK47 - HIGH CAPACITY AIR CLEANER
KC4 - ENGINE OIL COOLING SYSTEMKG7 - 125 AMP GENERATOR
KNP - HD AUX TRANS. COOLING SYSTEMLMM - DURAMAX DIESEL 6.6L ENGINE
MW7 - ALLISON 6-SPEED AUTOMATIC TRANSNC7 - FEDERAL OVERRIDE
NC8 - CALIFORNIA EMISSIONS ULEVNE1 - 50-STATE EMISSIONS
NQG - TRANSFER CASE, MANUALNZ3 - FULL SIZE SPARE WHEEL
QB5 - 16" X 6.5" WHEELSQIW - 16" ON/OFF ROAD BW TIRES
R9N - PROCESSING CODER9Z - POMS EXPEDITE-SOLD ORDERS/TSE
SLM - STOCK ORDERST74 - HEADLAMPS
TUV - BATTERY, DUALU2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
UE1 - ONSTAR SERVICE: INCLUDES 1 YEAR SAFE & SOUND PLANUJ6 - TIRE PRESSURE MONITOR
UQ3 - ENHANCED AUDIO SPEAKERSUS8 - AM/FM STEREO WITH CD PLAYER
UY2 - CAMPER/5TH WHEEL TRAILER WIRING PROVISIONSV10 - RADIATOR COVER
V22 - CHROME GRILLEV73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
V76 - RECOVERY HOOKSVB3 - CHROME REAR BUMPER
VG3 - FRONT BUMPERVH9 - ENVELOPE OWNER INFO MANUAL
VK3 - FRONT LICENSE PLATE MOUNTVR4 - WEIGHT DISTRIB. PLATFORM HITCH
VT7 - OWNERS MANUAL ENGLISHVXS - COMPLETE VEHICLE LABEL
X88 - CHEVROLET CONVERSIONYD3 - BASE AXLE
YD5 - BASE FRONT SPRINGYD6 - BASE REAR SPRING
Z82 - HD TRAILERING EQUIPMENT PKG: * LOCKING REAR DIFFERENTIAL * INTEGRATED TRAILER BRAKE CONTROLLERZ85 - HEAVY DUTY SUSPENSION
ZIZ - 16" ALS BW SPARE TIREZK3 - PULL AHEAD DESIGN
ZY1 - SOLID PAINT
1,456
Well in this excitement, trans seams to shift fine though dash doesn't work, and after 2 hrs of running the cab inside smells like burnt wires?
1,456
I pulled it out and pulled the case apart Saturday, I didn't see anything that would look like burnt stuff
1,456
If you can smell it, it should be very visible. That board is not likely it
Unless is buried in a harness somewhere..
The interior stayed mostly intact didn't it?
Yes, the seats and carpet/vinyl stuff got pulled to get to the middle Cab bolts, I didn't touch the dash.
Probably be Friday before I have decent amount of time to dig into the dash
1,456
Pulled some stuff out haven't found anything yet..
Trying to back track/reverse diagnosis stuff
Given this video of me trying to start the truck..
Source: https://youtube.com/shorts/1Ya4wLTB-8I?feature=shared
My brain is thinking, if I can find where the relay controls are for the starter relay which is probably close to the run/crank relay controls. Should give me a starting point of sorts.
So far all I can find is load side circuit not control side circuit, for both run/start relays ?
Edit found BCM pin out diagram.. all the problems I'm having running through.. it including PK1444 circuit runs right through it...
Think I lost the BCM or at least part of it???‍♂️
