If you want to run faster than 10.00 at an NHRA dragstrip, you will need your rollcage "certified" by the technical staff at the NHRA.
I called 626 250-2485 and spoke to Pat Cvengros. We set up an appointment to inspect our cage. He brings an ultrasonic micrometer to measure the bar thicknesses.
It will cost you $130 for the "sticker" which needs to be visible to track tech officials. If you want to powercoat, do it before inspection. It is good for 3 years.
Get an NHRA Rulebook before you start. You need 1 5/8 OD tubing, either .083" if 4130 Chrome Moly, or .120" thick if mild steel. Casper was fitted with seamless .095" 1.625 tube due to the SCTA (Land Speed Racing) requirement.
But let's get real. I will die someday, but I'd rather not have a pickup truck decide when. So I had more than the minimum done to protect the driver from injury.
Mitch Howe of Mitch's Custom Fabrications (El Monte, CA 626 442-2100) did the rollcage. Thanks out to Chris (Neens) for turning me on to Mitch.
Now here's the pics,
Please excuse Bill Gates and Friends. Windows Vista sucks very badly and MSPaint doesn't actually work correctly anymore, so I can't put text in most the pictures.
