I didn't find that specific diagram, but deducted crank signal from key runs through the BCM, along with DIC, PRDML information, warning light signals. Through several othersThis?
Yes engine starts if I jump the relay or starter itself.. though initially GP don't cycle, alternator doesn't come on, water, oil, fuel, coolant, tach, speedo, trans temp gauges are all dead., traction, brake, abs lights are on, T/H light doesn't activate, neither does the line under the PRDML light up, more often than not I can't connect to anything via a scan tool through the OBDII portThis is the LMM starting circuit from GMs electrical manual. The ECM is what sends the signal to the start relay
If you have the key in the run position and jump out the start relay or even the starter will the engine start?
Sounds like an issue with the databus. One time while driving an LMM I had to clear codes and my V2 came unplugged during the process and everything went blank but the truck still ran. Pulled over and shut the truck off to get everything to come back on and truck wouldn’t start. Nothing had power, waited 15/20 min then heard a thud under the hood like the ecm reset and everything went back to normal.Yes engine starts if I jump the relay or starter itself.. though initially GP don't cycle, alternator doesn't come on, water, oil, fuel, coolant, tach, speedo, trans temp gauges are all dead., traction, brake, abs lights are on, T/H light doesn't activate, neither does the line under the PRDML light up, more often than not I can't connect to anything via a scan tool through the OBDII port
From what I've gathered it's switch/BCM/ECM/starter relay with all safety switches in their correct position
What rim posted
That's the way I'm leaningBad BCM?
New seams to be around 2-250.. used seams to be ,~65-70At one time a new BCM was only like $100 for these trucks. They were that popular for getting fried and needing to be replaced.
I am not surprised Post Covid and all.New seams to be around 2-250.. used seams to be ,~65-70
Plus what every it cost to reprogram the new unit
Is that Post Malone's illegitimate brother?I am not surprised Post Covid and all.
Most likelyIs that Post Malone's illegitimate brother?
From what I've found there vin specific stuff additional to VATs which I disabled with EFI liveWhat about finding someone parting out a vehicle? Or a dismantler? I think as long as it comes from a vehicle with the same options, number of doors, etc then you only need to do a VATs relearn
