How big can one go with a single?
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
How big of a single can one get away with? I can spool it on the start but need it to mantain going down the track(drag racing). Im thinking of maybe going to a GT 47. Do you all think it will work? Thanks Jeff
eds04max
May 7, 2008
412
Landis, N.C.
Hey Jeff, if you're up for a 5 hr ride, we got a money race here in N.C. this w/e.(Sat.)
The track is alot closer to you than OBX. They say it pay's $600 to win.
Come-on down if ya' can!
Later, Ed.
HMMMMM..............47.........dat's BIG!!:eek:
JOHNBOY
< Rocking the Big Single!
Aug 30, 2006
2,159
Saegertown, Pa
Are going to use spray? I think it would be to big for just motor. I would think that a GT42 or GT45 with an external gate would be an awesome setup if you want to use lots of spray.
vortecfcar
No longer a member
Jun 28, 2007
167
It's driveable, certainly... but the only way I would go bigger than 80mm is if I had a motor I could shift near 5000RPM. This thing needs RPM to do it's dance. I'm shifting at 4200 right now and it wants more, I just don't want to break valvetrain parts (stock).
Here's a video of it on a 3000uS tune, shifting at 3800RPM
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Biggin!
Ed, I wish I could but I have my truck apart :mad:waiting on parts. I sure do like coming down your way for some fun! It will probably be spring before I get it going at the rate i'm going. I'm sure I will see you in the spring. I have to take my son pulling his Cub Cadet this weekend anyhow. It should be fun anyhow I put NOS :Don my buddy's Cub for the run what you brung class! Thanks for the invite. Johnboy, I say no spray BUT! i'm sure I will. For what its worth I have a way to get the turbo to light on spoolup so i'm only worried about keeping it lit. Thanks Jeff
z79outlaw
Apr 20, 2007
793
Salem WI
Sheesh I thought you wear only joking when you said you were running a S480, and you only have got a trans go and a single disk converter? You are crazy man, when does that thing start to spool on your truck?
vortecfcar
No longer a member
Jun 28, 2007
167
I wouldn't kid you :)
Watch the video and turn the speakers up or watch the speedometer needle. When you hear the big whoosh and the needle move really fast it's 'spooled' :D
JOHNBOY
Aug 30, 2006
2,159
Saegertown, Pa
A cam change will help spool up.;) At least it does for me.
Jeff I am afraid that a 47 will not stay lit if your rpm drops below 3000. I really think a GT45 is a better choice but pricey. Forced Inductions has cheaper plain bearing versions. My tractor buddys say that large s400 spool better but do not run as hard. You can get a budget s400 - 80mm with T4 housing for around $1100. See bottom of link. http://www.forcedinductions.com/productsborgwarner.htm
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
Stop when the hood wont close or the bed doesnt fit it:D
probably need to consider the housings and what type of drive press
and also shift points
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Hood
Its funny you say until it hits the hood. I want to cut the hood and bubble it around the turbo. Like alot of the car guys are doing were just the inlet is showing. Jeff
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Casper is pretty streetable with a GT45-sized charger, but it tuning is very important.
I will be playing the High Tech Fat Bastard which is about the same size as a GT45 but plain bearing instead, so it's cheaper.
It will not "plug and play" with a GT42 or GT45 charger, so when I do the install I post notes.
The most streetable of the "big" chargers IMO is the S400 with the 3.0 inducer. Seems to have a wider map than the GT42, but slightly down on HP.
codyn
412
urbana ohio
depends what you mean by a 3.0 charger;)
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
best of both worlds? IMO
hose the S400 with 3 or 4 stages. Or one simple stage to light and tickle it down the track.
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
Jeff the one thing about the hood is that it's not just the hood that it would hit
it's more the top of the fire wall
if you did make the custom hood though that would be very cool!
