Ben might...
Sorry kid, had to say it![]()
Anyone with colorful graphing software can make good rods I thought?
Ben might...
No. Simply because diesel fuel requires too much air to burn it, and it burns too slow. The best we can hope for is to catch up with gasoline engines, but that's a long way off.
is it from the rpm limitation ?
Where it stands:
You have a 400ci supercharged gasoline engine. 2000HP is doable in drag trim. 2000HP would be hard in a diesel without nitrous.
I have forged 6AL 4V bar stock and someone to heat treat them.....just no one to machine them.....wanna try![]()
I'll be your Huckleberry........![]()
So the fuel is the limiting area, I know this is off topic but it is there possibly a way to overcome this?
Diesels are special because how fast we can make the "slowest" vehicles on the highway. When I was growing up, a diesel pickup defined the term "slug". If you looked in the dictionary under slug, diesel pickup was one of the listings.
When you show up in a 3/4-ton pickup at the local dragstrip and wipe out Mustangs with it, it attracts attention. When they find out it's a diesel, their jaws drop. When you tell them it gets 20mpg and you can tow a 14,000lb trailer with it, they start to drool.
Audi is using custom made diesel racing fuel, and they are still limited to 6000rpm in a class that most engines are running 9,000 rpm. That's giving up 50%rpm to the gas guys.
Unless a new technology comes around that allows diesels to be efficient at high RPM's, they will never catch the gassers in that area.
We can run far higher boost numbers than they can, and trade RPM for boost.
Getting 75 psi "clean" boost reliably in a diesel will make us competitive with the best of gas engines in the racing arena. But right now, even though some diesels run 120 PSI boost, it's often just superheating the air, so it's not making more power than 75 psi of cool air would make.
...The truck is fast, but hell if I know how...
I have had this exact thing happen to me at the track. I would think most of us that run 12's or better have.
Wait a sec. We get more power at lower RPM than gassers, dont we? A gasser has to run higher RPM to gain power, correct? So why isnt a diesel at lower RPM competetitve with a gasser at higher RPM, given equivalent power output?
Dont mind me...Im a hi-perf idiot. The truck is fast, but hell if I know how.
What happened to numb nuts?
he wasn't banned as far as i know.
Perhaps tonight is his esl class.
shesh.......................... did i psell that wite?
