i know the G is a billet stator and im fairly sure the R and K are as well.
What does the lock up feel like under light or mid throttle, Mark? Thanks!
Mark.. That converotor fix the issues I have with mine blowing through the TC?It's the smoothest setup I've felt to date. Completely changed the way Shime's truck drove and it was pretty damn good before but this was the icing on the cake to say the least. I think I need to put one of these in my LML and see what happens cause the stock converter sucks! This is the converter that I will be putting in my LMM and White Lightning for sure.
Yes, those all are... I can get a K but, have to go through Mike L for that and my cost goes way up.
Yes sir it will!
I showed this to Mark while back..and he mentioned the 74 was being worked on.. Even after swapping to the gt4088r I can still repeat this.Marks chargers come on early and blowing through converters was an issue and was one of the main reasons for the 74.
Looks like the converter is too loose and not coupling at all. The speedometer should be following the tack needle a lot closer.
Bone stock Trans never been opened.. On a truck that's dyno 400rwhp
And how back to the argument.. TTC will lock up regardless of slip % and I said it would.. The tcc didn't engage till top of 3rd
