converter with Danville 68mmstg2r
MarkBroviak
DMax Junkie
2,231
740
Danville Indiana
What does the lock up feel like under light or mid throttle, Mark? Thanks!
It's the smoothest setup I've felt to date. Completely changed the way Shime's truck drove and it was pretty damn good before but this was the icing on the cake to say the least. I think I need to put one of these in my LML and see what happens cause the stock converter sucks! This is the converter that I will be putting in my LMM and White Lightning for sure.
1,457
Mark.. That converotor fix the issues I have with mine blowing through the TC?
Hernpj01
On a Time Out
Sep 23, 2014
403
Indiana
mark
you going to ad the 1074 to the lml trans and keep stock internals? will this help with driavability with the stg25 68mm on a lml? I know all the tuning tables are limited.
Thanks
1,457
Marks chargers come on early and blowing through converters was an issue and was one of the main reasons for the 74.
I showed this to Mark while back..and he mentioned the 74 was being worked on.. Even after swapping to the gt4088r I can still repeat this.
Lmm 36k starting up hill: https://youtu.be/thdUZDh0bgo
That 74 will make stop n go traffic alot nice to be in while towing
Mike L.
Got Sheep?
15,681
Fullerton CA
Looks like the converter is too loose and not coupling at all. The speedometer should be following the tack needle a lot closer.
1,457
Bone stock Trans never been opened.. On a truck that's dyno 400rwhp
And how back to the argument.. TTC will lock up regardless of slip % and I said it would.. The tcc didn't engage till top of 3rd
Mike L.
Got Sheep?
15,681
Fullerton CA
I don't understand what you are trying to say Adam.
1,457
That's factory stall/coupling whatever you want to call it... Nothing has been done to it(transmissions).. Truck was unmolested untill I got it..with ~95k on it..
If I push harder it will hold at ~3000rpm
Basically I need to dig up the thread about TC slip table limits for TTC engagement that efi doesn't show. Which are pretty evident in the video..
Said thread...
http://www.duramaxdiesels.com/forum/showthread.php?t=64415&highlight=Slip
