Great info and job as usual Mark!!
Congrats and stock heads aren't so bad after all!
That pressure seems high on the surface, but when you compress 65 PSI the max chamber pressures jump a lot. Its not like your going from Zero PSI to Oh My God either. Just the compression will bring you up to about 250 bar.
The other thing is you really don't need high resolution on the pressure plots. 1°-2° resolution is more than adequate.
How come some of you don't like the duals? Was thinkin about goin with a set for the reliability and not havin to dig in there to pull stocker for stroker.. Just wondering y some don't like them? Is it the cludder,wiring or st of that nature? I tho two stock pump put out more the the 12mm? Just tryin to figure out best option... I will b goin to the stg2r as well btw....
Thanks and unfortunately yes they do suck. This turbo will make 1650++hp on a real setup without batting an eye. I made 1440hp with an 88mm turbo with a 2.6 cover on it with a real motor setup under it. The difference in the heads is rpm power curve, power under the curve and egt control versus power output. Unfortunately the heads I had have proven to be a very sharp double edged sword and you can only stand the bleeding for so long.
serious question.Like I said before, singles eliminate all the clutter and make the diagnosis much easier when you actually do have an issue. The 12mm will support 1500hp with the right air combo so realistically it is the best pump choice for most guys out there.
serious question.
From what I understand dual pumps flow a decent bit more than a 12mm, so how much power can a set of stock lbz pumps actually support? I didn't think it was that much, 1500+, otherwise why the need for triple cp3 kits and front covers that can run 5 of them.
Sent from my SM-G900T using Tapatalk
It depends on the total combo but around 1200 hp possibly a little more. They flow about the same as a 12mm pump but not quite as much.serious question.
Jon, what do you feel is the safe limit for pressure on your cast ovals out of curiosity?
14mm At 4,500rpms this pump has an advertised output of 7.5L/min @ 1800bar. In comparison for reference, a stock pump at that rpm is 3.2L/min, Sportsman pump is 4.3L/min, 10mm is 5.3L/min, 12mm is 6.2L/min at the same 4,500rpms @1,800bar. Hope this helps out guys! I will keep you guys posted if I decide to push it farther in the near future!:thumb:
serious question.
You need to remember there us also return that has to be accounted for.So those flow ratings work out to roughly the following gph numbers
3.2lpm = 50gph
4.2lpm = 68gph
5.3lpm = 84gph
6.3lpm = 93gph
7.5lpm = 119gph
Do we really need lift pump rated at 3x the volume or does 2x be sufficient?
In general application..
with understanding OEM lines even though 1/2" don't flow well considering all the bends and junctions in them, as say -8 braided line
And the understanding that even at full flow on the pumps its not sending 100% of pumped fuel to injectors
We will see what two stock LBZ Danville modded pumps make here in the next couple weeks. I dropped my race engine off at Danville so we can get a base line on how much power I was making the last couple years.
