Great stuff here. Good job man!!
Sent from my SAMSUNG-SM-G928A using Tapatalk
Just curious what you think is holding the power back? A good 91mm Turbo should make 1500 fwhp+, or was this on the chassis dyno? Awesome on a single pump for sure! Keep up the good work and R&D! :thumb:
That dyno is a heart breaker too!
I honestly am not aiming to start any crap whatsoever but are these most recent versions of modified pumps (stroker pumps) from Exergy, Fleece, ED, etc. having any reliability issues like the ones from FloorIt, II, etc. used to have back a few years ago? Or are they pretty stable pumps these days?
Those are some really impressive numbers.
How well does the pump maintain rail at the initial onset of loading the motor? We always felt way back before they allowed dual CP3 in the old old 2.5 class (no where near the current 2.5 class that exists today) that the biggest advantage to dual CP3s was the recovery in the beginning. The duals could just maintain rail pressure so much stronger in the early part of the pull as compared to the modified single CP3s back then. Of course, the big modified single CP3s recovered and maintained rail on down the track but it took time. Just wondering if these newest stroker pumps suffer from that or if the extra volume per stroke keeps the pressure maintained sufficiently?
Cylinder pressure impresses me the most! JD 13.5L crankshafts don't like much over 250+ bar, and Mahle Monotherm pistons crack at sustained 230+ bar in the test cell, but it's the sustained temperature with all emissions stuff at 630hp....but head gasket usually failed or cracked cylinder head before both of earlier mentioned things.
They used OSIRIS in the test cells, I would love to have means to run it on our pulling truck! It was accurate to 1/10th of a crank angle degree, and man could I see what one little tuning change could do to cylinder pressure and temp, amongst other things!
I would love to run a single stroker, anyone interested in a PPE dual fueler setup
I think in the opening post Mark said cylinder pressure was 302 bar? What does that equate to in psi?
Me too wish I had talked to Mark before I bought a Ats twin kit. What I get for thinking on my own:roflmao:
How come some of you don't like the duals? Was thinkin about goin with a set for the reliability and not havin to dig in there to pull stocker for stroker.. Just wondering y some don't like them? Is it the cludder,wiring or st of that nature? I tho two stock pump put out more the the 12mm? Just tryin to figure out best option... I will b goin to the stg2r as well btw....
