FWIW, the built 4L85E in my race van project is holding up well so far, but so far I only have 7 1/4 mile passes at the track and some street testing on it. It is a lot lighter than a fully loaded truck, but I'm also putting out a lot more power than what you're looking for (enough to trap at almost 113 MPH). If you want to talk to someone about its ability to hold up, Jake's Performance built mine. They could tell you whether or not it would hold up.
ouch![]()
only code thrown was open cruise control brake circuit.. which it doesnt have cruise control..
also read your 8.1 dmax swap intreested in how straight forwar it was.
i figured that..(6.5 GMT400 turcks) i wanted to know if the 8.1 GMT400 trucks had the same harnesses or some type of hybrid cross over harness between the 400 and 800 trucksbut it does have a brake pedal switch.
and that works just fine..:thumb:
swapping a dmax into an 8.1 avalanche is nothing like what you are going to be doing adam. the avalanche and the dmax pickup trucks share the exact same electrical system/harnesses.
The 8.1 broke the crank? How many miles?
you got a link to where i can get that conversion CD at? i am not familure enough to figure out how to look up `pussow`
the catch with the tranny.. IDK if you know or not but on these truck then praking brake is driveshaft mounted on the tailshaft.
IDK if the allison trucks are tailshaft mounted or even they are still running D80s or AAM1150 havent had a chance to crawl around one.
BTW the 2886 and dmax fan blade.. 205* ect sustained is the max i get..thats 26,000lb up a 5% at 30mph(2nd gear) for 6 miles or high wind resistant loads... wouldnt do run it on a regular CK truck though.
thought you would like some feed back :beer
i know you pushed lotsofsmiles 4l85 failures in the thread you posted.
im going to ask him what actually failed.
