WOuld delipping and coating LBZ pistons make them stronger or more crack resistant?
last i heard lbz were crack around 600ish vs the 700-800 lb7 were lasting too.. dont know the excats on that...
The advantage to delipping, cutting, and coating would be done for the same reasons as going with the twin turbo kit. The twins allow you to do more and have a much more durable motor at the high hp demands. It is a well spent investment.
I'm not exactly sure what hp I was at with the stock LB7 longblock but in the fall of 2006 I ran a best of 11.53 @ 117.63mph on fuel only in the 1/4 mile with a race weight of 6600#. That motor had about 110k miles on it and about 300 combined 1/4 mile passes and hooks sled pulling. When I pulled that motor out ever rod was bent so I got my monies worth out of it.
good to know what did the pistons look likei am still seeing that not many have cracked a lb7 piston and if you know of someone that has what were the conditions high egt ect ?
I cracked a stock lly/lb7 piston on 500hp tune seeing some serious egt's though in the dunes . When it let loose I wasnt on it like normal either . I was at 1700 , but only for a few seconds and boom . Really felt like I had weakend them previously from high egt's . It let loose at a time you wouldnt have expected it to .
I think it is random . I did the same to a motor for 45,000 miles with no issue and pushed a head gasket . Everything looked good inside . Put in new motor in and it only lasted 12,000 and cracked a piston . Go figure . Random ......
New motor in truck now has guys delipped LLY's in it . 7 of them are my old pistons . A little worried about the heat cycling the other 7 have seen , but sometimes $$ plays a role in our builds . You have to go with what you can with $$ as a factor sometimes . I made the choice to take the risk .
Many say delipp and I have a few other guys I know that say it isnt cracking from center out , and that it is cracking from wrist pin in . They said dont delipp it wont help . You will always have many different opinions and you just have to go with your gut . My gut said delipp . I did it and am happy with it so far . Only way to find out is to try something new . I know I can crack a lipped piston already on only a 500hp tune . So this was the right thing to do in my opinion .
I really believe it is heat cycling making them weak or just a random flawed piston out of the bunch . Time will tell if delipping helps them last better with same heat cycling .
You have to go in a direction . I went with delipping them now . I know I can crack a stock lipped piston . Thats known already . So why not go with something new and see if they give up like lipped one did .
Time will tell with the delipped ones in it now . All is good so far .
In the past I had stated I thought the bottom end torque felt like less , I was wrong it is still as good as before . It was my cracked intercooler making it lazy down low blowing off boost at leak . Feels as good as ever now with new intercooler . Same power as before with lip on .
I would delipp if it was mine .
This is a good point about the heat. However, I don't know if my experiences play into it, but at my elevation (6000+ most the time), I can see some huge EGTs (1800-2000+ briefly sometimes by accident) while going through the mountain passes. I know I ignored the EGT gauge many, many times when I shouldn't have. None of my stock LB7 pistons cracked (luckly). Now I'm running Guys cut pistons (non-coated) and I've had good luck for the last 9 months and about 10K with the same treatment. Not saying that there not going to, just I've been lucky maybe? Just throwing this up so we can get some ideas of what's happening here.
Hole/crack LMM Piston, 15k miles, 500hp.
what were you egt's like with that kind of power ? we are debating on the link between egt's and piston failure , there seem to be alot of twinned trucks running the lbz/lmm's pretty hard without failure yet unless you know of some one ? and if thats true for the lmm/lbz why not lb7
JoshH put a hole in one of his pistons after twins IIRC.
I'll be able to say more of what caused my cracked piston soon but it was on a 540+hp motor with 150 or so passes and daily driving like I stole it. Stock LB7/LLY pistons. Ever since i got faster than 12.8s the EGTs haven't been over 1400*; prior to the Cheetah and injector my EGTs were higher (buried an 1800* gauge a few times but not for long). Mine also failed when I was being easier than ever on it. I'll post more in the next week or so when I tear the motor down.
The highest timing I ran with the bigger injectors was 26* and that was only from 3250RPM and above. When you only have a 1960 PW you don't need much timing to get your fuel shot in.
