The main problem with those is by the time you need it, it has fallen off or been moved...CRS: the real reason post-it notes were invented.
Hell, I just found some new parts that I forgot I even had...
Probably good you can’t find those Mishimotos anyways.Had/have some mishimotos sitting in a box somewhere. Can't find them since I've organized my shop???
Picked up a duralast set from AutoZone
Like finding money in the washer/dryer ?The main problem with those is by the time you need it, it has fallen off or been moved...atleast in a case like this...
Pretty much. "Hey, we're did that come from?"Like finding money in the washer/dryer ?
Napa used to carry skf hubs, IDK why they dropped the lineRock Auto had SKF hubs for $78 yesterday when I looked. Yes, I immediately bought two.
Outside the antiseeze I put on... IDK this all they give,What kind of coating is that supposed to be on the hub?
I've been running cheapo lifetime hubs from 1Aauto since 2016, torqued slightly below spec
I suspect that one is going to be E coated. Basically a thin layer of epoxy paintLooks like DLG version got similar treatment
