You are correct Tom.In my experience, lift numbers WOULD be affected by rocker ratio. Duration would not.
give me more cams to measure...One thing I have never seen over the years was an actual cam spec comparison between the different Duramax models. We've always assumed they were the same throughout the years, but its looking like they werent. Would be nice to have that info in one spot.
hint....hint....hint....
Frankly I am sick of the secrecy... Some of these trucks are over 20 years old now... Some of the products out there are over 10-15 years old... There shouldn't be any reason to hide it. Yes, its a small community and the mark ups are high on some of the stuff. But as you mentioned, something like a camshaft can drastically change the driving characteristics of the vehicle.I've often wondered what the difference between cam lobe specs was between engines. I know most diesel guys don't see the importance in cam selection, but it can drastically change engine response at different RPM ranges.
The first one I posted was an 06 LBZ cam from my engine. Never hurts to confirm though.I might have a LBZ cam to measure soon. Callies gives cam cards. I have a cam hear from Straub I am going to try in my own truck. I will put those specs up.
@Harshman , are you using the bench from them as well?Performance Trends software
www.duramaxdiesels.com
