http://www.rareelectrical.com/p-427...-00-01-02-03-04-silverado-truck-321-1803.aspx
I guess they are 250A, but here is the information on it.
Howdy, are you still having good luck with these alternators?
AcDelco 145amp alternator showed up today. No fittment issues. Odyessey batteries are on order.
I replaced the anemic fusible link charge wire to a 4 gauge cable, I also added an additional 4 gauge charge cable from the alternator to the passenger battery. Take a close look at the stock charging system, it was not designed for optimum charging to the passenger battery.
I had some unexpected results after replacing the alternator with one that put out 150 amps at idle and it was not the Denso hairpin alternator as planned and did not use an under sized pulley ...![]()
the one I bought years ago still works
I think I clicked on the wrong quote!
did you end up getting the Rare Electrical one?I've bought quite a few of the rare electrical ones and to my knowledge, my customers have only told me about one of them not lasting very long. Bearing failed. Maybe 1 of 20 or so? I've had more issues lately with voltage regulators in the 08+ style than anything. I get them rebuilt locally most of the time and keep some in stock.
I've had very good luck with DC Power and Mechman. The DC Power elite 270A on our shop plow truck has been flawless for the last 5 years. One of my Mechman 220A has been great on my LB7, the other isn't installed yet as I'm going dual alternator.
Anyone heard of or tried the Powermaster from Dmax store?
It says it's new and not a reman.
Summit and JEGS are cheaper than Dmaxstore
2007 LBZ, CCLB dually, 475 over stock, EFI tunes by Idaho Rob (damn EPA), 30% over, Mike L built tranny, other odds and ends
Had one on my lmm, it didn’t put out much amperage at idle. At times the low charge light would come on. There are better options out thereAnyone heard of or tried the Powermaster from Dmax store?
Not sure about Lbz and older but on my lmm I got an alternator from an L5P they’re 280 amps, if you need more get one from an L5P ambulance I heard they’re over 400 amps
For the lbz they make a bracket that puts the second alternator where the dual cp3 would be. Then you can get the wiring kit to splice it in. You can not have the positives outputs touching anywhere. They are separate systems for the regulators.Is it a direct fit or what is required to make them fit?
The l5p alternator won't work on an lbz or older. Up to the lbz gm used the 4 pin regulator, lmm+ went to the 2 pin regulator that works with the charge control module.Is it a direct fit or what is required to make them fit?
