I have been debating about what to run on the street to be able to hook up, at least somewhat hook up. What are you 2WD guys running in the rear to hook up on the street?
If you're making much power, there isn't really any normal street tire that will hook up on the street. You'll have to run a DOT slick or drag radial to even have a chance, and even those don't work that well on an unprepped surface.
Need a lot of weight on the ass end to give a chance to a street tire
The fact he’s got a short bed helps and it’s 4 linked. I’d probably set that ass end up real soft on compression and spring rate, then run the shock valving to control launch. Start at 0% anti squat too, might have to go negative. Front end will need to be real loose too.
Tires will probably still spin at will under high hp but that will give them a chance at least. Weight at the back end is still highly needed
Hell yeah! I will say when I ditched the torsion bars and did coilover conversion on the front it made a night and day difference in mine. I really want to link my rear, may have to do it this summer!
Who did your link setup?
Id buy custom offset wheels and run very wide tires in the rear.![]()
Oh, youre that guy! :rofl: Thanks for jogging my (fading) memory.
Glad to see you brought your build over here. Welcome!
