Found a little rubbing from the lca bolt to the DHD brace. I cut back the bolts to clear
I just put my brace on today. Turning right seems all fine but turning left I lost a lot. Is it the bolt on the LCA that I may be hitting? I will have to check in the morning.
4 1/2" peanut grinder will work just fine joe
I just used my angle grinder with a cutoff wheel. Could probably use a reciprocating saw too.
Aight. Maybe this weekend I might get to it.
Did you put the brace on already? Or are you doing the whole project.
Flip the bolts, way easier and the other side is slimmer. It won't rub. Trimmed my bolts and it still rubbed on the nuts so when I did LCA's I flipped em.[/QUOT
Nice
Nice
That's what I was looking at. I don't think trimming the excess thread will be enough on mine.
I have the ss kryptonite centerlink and this brace fit perfectly with it. I had to trim both lca bolts too.
I'm gonna flip the bolts around when I install mine.
