How much voltage will the electronics handle? Will they be ok at 19 volts? I'm sure there is some room for more just not sure how much is to much. Thanks Jeff
Also as voltage increases amprage decreases. Wire size is dictated by amperage, so with higher voltage you can run smaller wires.....not that there would be much to gain from doing that:baby:
I realize that as voltage doubles amperage halves, but really, how many amps does an ECM, instrument panel cluster, BCM, and lift pump draw???
The ECM is an electronic device, and like most electronic devices, likes 5vdc. Whats it going to care if its regulators see 14 volts vs 19 volts......??????? So we bump the voltage up to 19vdc, great, we just cut the ECM's current draw from 2 amps down to 1.5.
I just dont understand the logic behind this I guess is what im trying to say. Whats wrong with the way the truck runs now?? Maybe on a race car it gives it hotter spark or something? I dunno.
ben
I am by no means an electrical genius, but as I understand ohm's law, Voltage = Amps * Resistance. To me, if resistance stays the same and voltage increases, then amperage must also increase, or am I missing something?
Has anyone ever looked at what or trucks use(amp draw)at high rpm? EVERYTHING on these trucks use power. Everything electric works best just before it burns:rofl: up. So if I can figure out the point just below that I think it will help. Could it not hurt to have a little higher voltage with the injectors firing at 5000 rpm? With electric fans, they blow harder, Lift pumps push more, starts easier with lower compression. If it helps any at all it will be worth it to me. Just wait until I break the ally and show up with a 2.10 400 turbo and a drop box in it.
Thanks for the explanation, Fingers.Upping the voltage will do you no good for any of the controls. They regulate the supply voltage down to a standard regardless of the input. The only exception being the glow plugs might glow a little hotter.
Folks are mixing the two concepts with regards to Amps. The two formulas that describe things are:
Volts = Ohms * Amps (Ohms law)
and
Watts = Volts * Amps
Anything with a fixed resistance will draw MORE amps at a higher voltage. However, you also can get more power out of the device with more voltage. For instance, an electric motor. That is, till you burn it out.
The case of the 3 phase motor is a little mis-leading. Though the amps may be lower, the motor uses and produces the same power at either voltage. To switch between the voltages you have to configure the winding for that voltage, thus changing the internal resistance. The advantage of the higher voltage is that the wires feeding the motor can be of a smaller gauge with the higher voltage. With the price of copper what it is, this can be huge in applications using 00 or larger wire.
