Dual MAF sensor conversion box
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
Is anyone interested in a module like this?
It would let you run parallel twin turbos, with two MAF sensors, one on each bank/intake.
It takes both MAF sensor signals, adds/averages them together, and multiplexes them into one signal wire that you can then feed into the ECM.
This would be much better than just running one MAF sensor on one bank, and then spending forever to dial in your MAF flow rate table...which is kind of hack because you have to halve the whole table, etc...and you arent getting a true reading of mass airflow thats going into the engine when you datalog it.
I designed it as sort of a one-off for a twin turbo marine application, but figured I would see if there was any interest for a few other people to help spread out the cost......
Ben
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
What kind of money would something like that cost you think? I would be interested depending on cost.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
Ill have to work up a price, probably not too expensive.
The box has some "smart" logic/fault diagnostics built into it...there an LED on the module to blink error codes.
Fault 1: if the two MAF sensors differ by more than 10lbs, it sends a signal to the ECM to set a P0101.
Fault 2: MAF sensor 1 is reading lower than .3v (open circuit) or higher than 4.7v (short to +5v)
Fault 3: MAF sensor 2 is reading lower than .3v (open circuit) or higher than 4.7v (short to +5v)
Theres a "program" button on the module to completely disable the diagnostics if you want it to not care about MAF sensor errors or discrepancies....
Ben
5,088
682
Sounds like a great doohicky. I would be in for 1 when I do twins, but that's a little ways down the road.
13,862
966
Ben, I don't know how much of a market you will find for guys running parallel twins, but I could see it also being marketed to guys with triples. They usually run two filters and intake pipes also. Sounds like a cool product.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I was literally just thinking the same thing. I have no use for this product but it still impresses the hell out of me.
Harbin_22
3,858
Southern Indiana
I would take one for my tripple kit. It really is a horrible reading when you have another turbo bringing in air through another 4" hole lol.
Ditch the MAF. Speed density all the way on boosted LS stuff
And the tuners around here are ditchinp the maps and going all maf on the gas stuff. Helped somebody with one tuned by blackbear. He kept popping the intake boot off at the throttle body, and it would flood out everytime because it only used the maf sensor.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
Would this work on gas setups running an ls1b ecm?
I would have to make some software changes, because the 2007.5+ Duramax MAF sensor reads from ~1100Hz at idle to ~9000Hz at full throttle...LS1 reads ~4000Hz to 12,000Hz.....but yes, it could work on LS1b applications too..
Ben
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
How about some kind of (non DSP) two step/rev control for us guys leaning on a converter...., even with a Trans brake ��. Any way to do that without buying a $10k Bosch stand alone..
