On Edit I am 100% sure that Turbonetics makes it
Thanks, gave them a call and they are not on the market yet.
yeah, i seen a aurora 5000 with a wastegate like thatcould one not take a cast pedistal and drill a hole for the wastegate?
Could one not take a cast pedistal and drill a hole for the wastegate?
better off doing that to a welded tubing pedistal
Sure it can be. You need to make a spacer to to go between the pedistal and the turbo. Engineered diesel makes them.The Bullseye can't be gated
I believe the bolt hole pattern is 2.75 x 3.25. The gasket size I have is 3.6 x 4.35.
