No dual cp3 controller
DMAX497
Sep 27, 2012
398
Utah
What is the hype on the no dual cp3 there is no real information that I can find about it?
Can kory or fleece boys chime in? Is it done through EFI live?
Is it available to he public?
Thanks!
DPC
323
Adams, TN
X2. I have always wondered if you could just splice in another pump and scale the voltage accordingly with EFI. Kind of how we do it with big single pumps and modified FCAs.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
well you'll have to still run a custom built harness to piggy back the one single into the second pump... What's that gonna run if someone sold them? Probably charge 125 bucks just for that harness! I think fingers controller is about 300 bucks. If you rescaled the regulators to cut power in half, I guess in theory you'd wouldn't need the controller for that.... But then what's the ecm gonna think when when it makes twice as much fuel pressure then what it wants? I just don't see that happening. You'd have to foul the Ecm somehow to keep it from freaking itself out, I don't see you being able to do that with just efilive. That being said (and I could be off base) I'm still interested in hearing about this is.
DPC
323
Adams, TN
The ECM is going to do the samething it did when I threw 85% over pump on it, make the truck run like chit. It took me about 10 tries to get the rescale right through EFI. If guys can make 200% over pumps run I don't see why two pumps would not work.
bluessmax
Tabasco Injected!
Nov 4, 2010
1,145
Lake Charles, la
Brayden and I can do it no problem. We have been doing it for the LML, but is now offered for LBZ/LMM. It as though it came from the factory this way. 2 cp3s from 1 output.
Fingers
Village Idiot
1,713
84
White Oak, PA
I sell the controllers for $180 shipped to the public. The driver is rated at 4 amps and I fuse it for 3 to protect regulator and circuit.
The issue is the driving circuit in the ECM. Driving two FPRs requires twice the amperage. Each FPR takes ~4 amps dead short and about 1.5 amps if you keep the duty cycle less than 90%.
LB7 and LLY ECMs would trip on over-amperage. I can't speak for LBZ and later, but would be surprised if the driver can handle the load for long without over heating which would, BTW, trash the ECM.
S Phinney
4,011
Quncy, Fl
Fingers controllers work good. I don't see a reason to not use a part that was made to do it right without risking damage to the ECM.
Sent from my XT1080 using Tapatalk
GMC_2002_Dmax
The Still Master
I don't see any advantage, you still control it with an ecm, you still need a piggyback to split the single signal.
So at the end of the day I would rather run a controller then run a few wires.
Kind of like a relay for a electrical accessory, it takes the volts or amps you need to run something safely without worrying about overheating or overtaxing a circuit.
:thumb:
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
The CP3's are full blast when there is no current, it takes current to reduce pressure.
Sure, you can just run the CP3's with no controller. But it won't idle. It will only run OK at full blast. This is not actually useful.
To experiment, unplug your CP3 and try to drive your truck.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Cp3
After fighting a problem for two years lets just say to keep it simple. Every add on piece is just another thing to cause a problem or go bad. Keep It Simple Stupid!
Burn Down
Sep 14, 2008
7,093
Boise Idaho
Pat, Kory & Fleece are using the factory ecm to control both cp3's...
I'm with Stingpuller less is better.
bluessmax
Tabasco Injected!
Nov 4, 2010
1,145
Lake Charles, la
It has worked flawlessly on LML for hundreds of trucks. All h&s dual pump kits sold have this tuning on them. I like the idea of having a customer simply plug strait into the plug coming off the harness split
Into both pumps.... Takes around 2 mins to do and never worry about controller failure. My understanding as well is that a lb7/LLY could not handle the current, but LBZ-LML should have no issues. A few more trucks doing it and I will feel confident... We see folks with many random controller failures, and this is simply another option.
Pat, with our ECM tune it will idle and regulate as though it is stock with a single pump.... Follows factory curve from top to bottom.
9,903
149
How long have these trucks been running on one controller? I honestly think you would be taxing the system. Not sure I would chance it on a DD. Race application maybe.
Sent from my C6906 using Tapatalk
bluessmax
Tabasco Injected!
Nov 4, 2010
1,145
Lake Charles, la
Mine has been for 20k miles, HS truck has been for over a year.... And we have countless doing it on LML with no issues.
On LBZ there are only a few doing it now. So we will see how they hold up. I will also try and find out what exact load the driver can physically take. Obviously, this hasn't been anything we have marketed for anything other than LML. So only time will tell.... The idea of taking 2 mins to plug up your dual cp3 without ever having to worry about controller failure is a good idea, IMO. We will see how it works out!
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Cp3
Not to talk for Brayden or Kory but here's what I know. The ECM is rated at 4 amps. Now we all know gm puts in a safety factor above that. Each reg will pull .7 of a amp. Less than one amp each. Now for the tuning side of it that you will have to get Brayden or Kory because it's not just cut it in half on the regs. It won't work that way. It took a bunch of trial and error to get it were it would idle smooth. Starting was also a issue at first so it's not a plug and play without there help. Anything to make these things simpler is all good in my book.
GMC_2002_Dmax
The Still Master
It shouldn't be too hard to figure out, regulator scaling amp tables are available and the closed loop corrections are also available.
Anyone with some time to spare could play around with it, and any professional tuners used to correcting for mismatched pumps, modded pumps and or regulators should be able to "figure" out whatever is needed to make it work.
I would like to see if someone can actually measure load draw on the factory circuit.
As anyone who tunes these knows and anyone who has been around knows that it require no amperage to make fuel pressure at WOT, but requires a lot to clamp down the regulator to maintain idle and then correct fuel pressure quickly after chopping the throttle.
Maybe a dual pump kit is in my future for R&D.
:thumb:
bluessmax
Tabasco Injected!
Nov 4, 2010
1,145
Lake Charles, la
:thumb:
Yeah, it isn't too difficult. Efi doesn't have all the tables in their software for doing it.... But easily done.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
DOH!!! OK, I understand now.
Never gave it much thought since the kits come with a regulator. Hence you can use the kits with any type of tuning, handheld or custom.
Fingers
Village Idiot
1,713
84
White Oak, PA
Those are not correct values. As I posted before; straight DC, the regulators draw about 4 Amps. At 90% duty cycle, the impedance keeps it just under 1.7 Amps.
At idle, the regulators are at about 40% duty cycle. (single pump) 60%-80% dual pumps. OEM regulators are fully closed somewhere around 90% and fully open somewhere around 10%.
The strain on the power circuit is when the system tries to dump pressure and command max duty cycle. Unstable rail pressures work the hell out of the regulators too.
