That's plumbed in series and plumbed in parallel.... Both of which I understand the pros/cons
Where's series-parallel diagram for 2 water heaters ?
Not sure what he meant by series - parallel unless he was talking about four or more water heaters. But then again, first in last out works for any number of multiple water heatersThat's plumbed in series and plumbed in parallel.... Both of which I understand the pros/cons
The repairs are under warranty, but that doesn’t do much good when it shuts you down for day/s and puts you behind schedule. I spent 2 weeks doing 1/2 our normal production while we did the parts swap game, because we couldn’t figure out what was wrong with 1 machine. It puts the dealers in a bad spot. They don’t want us unhappy, but there is only so much they can do. Even if they say the will give us a loaner machine. It takes a day or so to get it to the job site.That's absolutely terrible. So at only 6 months or less old are they even doing anything?
I caught a lot of flack for not buying a new truck with a warranty when I was hot shottingThe repairs are under warranty, but that doesn’t do much good when it shuts you down for day/s and puts you behind schedule. I spent 2 weeks doing 1/2 our normal production while we did the parts swap game, because we couldn’t figure out what was wrong with 1 machine. It puts the dealers in a bad spot. They don’t want us unhappy, but there is only so much they can do. Even if they say the will give us a loaner machine. It takes a day or so to get it to the job site.
So, two atmospheric water heaters feed into one high pressure water heater? ?For diagrams it's correct on the general principle..
A series-parallel with three would be same as triple compound turbo routing
Clear as mudd yep lolSo, two atmospheric water heaters feed into one high pressure water heater? ?
Almost everyone I know of around here has deleted their pickup/semi. A lot of guys deleting equipment too. Back went we still had supply chain issues after Covid we had a machine down for 6 months or more. It was so long we almost forgot about it. Finally the developer’s lawyers sent us a letter they would be charging us a daily fee for storing it on their property. The dealer had to go out there and basically disassemble it to wench it up on a low boy and store it at their yard.I caught a lot of flack for not buying a new truck with a warranty when I was hot shotting
That's a cool set up!This gives me a hard on…
