LML LML custom tunes flashed via EFI?
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
hmm so wonder if it has LMM top end and electronics or there some beta going on here. or somenody messing with us with an H@S
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
No, its actually an LML ECM and LML electronics.
you guys need to understand that this is NOT being "tuned" with efilive though.
The efilive V2 hardware is just being used as a "vehicle"/method of flashing the LML with files that were written/modified using third party software. You guys arent going to be tuning your LML's yourself. The European software needed to edit the LML files costs $10,000+. EFILive is just being used to flash those pre-editied files into the ECM via the OBD port, instead of having to open the ECM to flash them.
ben
Harbin_22
3,858
Southern Indiana
Just got the EFI news letter. It said they are in beta with it now. So yeah it kind of is tuned with EFI. They did a good job keeping it quiet
1,601
So EFI isnt tuning LMLs, but yet is tuning LMLs. ;) Nice work-around! Way....to....go.....EFI!!!!!!!!!!!!!!!!!!!:thumb:
PWI on my computer
02CCSB
Built
May 24, 2012
391
Winnipeg, Canada
Correct me if I'm wrong, but from my understanding, the KessV2/Alienware hardware is able to read the LML ECM as a binary file and they have then converted it to an editable format? (FYI - this is still a $10K proposition)
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Where are yall getting the price from? Do they have a website?
Sent from my PC36100 using Tapatalk 2
Read people! :D
The Duramax LML comes close to the top of the list for customers asking for support as EFILive has historically been 'the' tuner to run for Duramax owners. Since hitting the Dealers' lots in 2011, we've held many discussions with many people on the pros and cons of supporting this platform whilst keeping a close eye on the struggles the European tuning market has gone through with their own versions of the EDC17.
The issue has been, and continues to be, that EFILive traditionally requires customers to read their ECM via the OBD2 port to generate the file to be edited and then re-flashed. The OBD2 read restriction in place from the factory effectively prevents this first critical step and simply cannot be bypassed, serious LML development never commenced based on this issue alone.
As we discussed in our January newsletter, EFILive plans on expanding our structure for adding additional controllers where customers create their own tunes with external software and simply use EFILive as a convenient way to deliver tunes to customers, much like the read/write functions that already exists in our software for the GM V6 Bosch ECM's (E55, E69 & E77) even though EFILive offers no mapping for these ECM's.
The Duramax LML will be the next ECM to be supported in this fashion as EFILive has been busy adding LML flashing functionality. With advancements in third party tools, our historical stance has changed. Given the OBD2 read restrictions, customers will be required to physically open their LML ECM, solder a wire to the PCB and read out their stock file using external hardware/software, then create and edit their own maps using third party map editing software. EFILive will simply provide the OBD2 flashing mechanism through our V8 software and FlashScan V2 and AutoCal hardware, giving tuners a familiar and consistent way to deliver tunes to their customers. Most importantly the V8 software will also implement checksum corrections to the LML files so they can be externally edited via other software and fixed ready for programming. Enhanced scantool data is already available for the LML.
Given the cost and complexity that needs to be invested to obtain and edit the LML file, this solution is clearly designed to provide those professional tuners who already support, or plan to support the LML via ECM exchange program rather than an individual looking to tune their own vehicle.
Our first release will not include any mapping, and EFILive will not offer any map finding services, however we 'may' consider offering basic mapping support for the LML in the future.
EFILive does not plan on offering any hardware solutions for reading the files out of the LML nor are we able to provide stock tunes for customers, we have however created a file import function for one of the European JTAG read/write hardware solutions.
Early indication suggest that a full setup for read hardware, software, along with mapping programs will cost in the vicinity of $10,000 USD. This is NOT a cheap proposition and is definitely targeted at high volume workshops, not individual tuners.
There are already several vehicles running custom tunes programmed with EFILive LML Flashing support. Further beta testing will commence shortly across a wider range of vehicles and public release will follow in the very near future.
