Brodix cylinder heads for the Duramax
S Phinney
4,008
Quncy, Fl
These numbers are for LB7 Federal Heads Stock.
These numbers are what just about all of the stock Dmax heads flow. LB7-LML. The port shapes and sizes are all basically the same.
The only exception is the LB7 EGR head. The intake ports on the EGR head flow substantially less. If I recall correctly about 40 cfm less. The exhaust ports are the same as federal heads.
So here they are. Let the marketing and advertising of flow numbers begin. :rofl:
That is nearly identical to the stock flow numbers that I have on my lb7 heads. 180 on the intake and 142 on the exhaust at .500 lift.
MarkBroviak
DMax Junkie
2,231
740
Danville Indiana
I love Guys stuff and use his heads on my truck. Im not in any way saying the Brodix are better then anyones but they are bad a$$
One of the best mods i know about these Brodix heads is they are cupless for the LB7 which i like. Jeremy shared a bunch more info that makes these heads look serious and promising but ill let him post up about the heads. There is a ton more mods to the heads and they are far from a ported stock head. From what i was told i think the $6500 is worth it.
X2, Guy's heads are all that I have sold my customers with great success over the years! I have been fortunate to be the test dummy for these new Brodix heads and helping Jeremy with the design and porting and fitment and I must say it has been a long road to get to this point. I installed the first set on my truck back in March. I am getting tired of swapping heads on my truck, but all the testing has been worth it. The test data is eye opening and has really changed the statis quo in my eyes. You guys are right, they are expensive and honestly they are not for everyone. The top 10-15% will buy these without batting an eye because they are more than worth it in quality alone and the performance increase is just icing on the cake. Look at my truck for example, with these heads I ran 10.96 in the 1/4 with a vgt and a single pump and did it while running 1400egt's at 45psiboost and 65drive. Put twins on and picked up 190hp 60psi boost 85drive. On the sled pulling side of things these heads have allowed us to run much larger chargers than before without issue and we have picked up a solid 600-1000rpms with them. Cams act different with them. The flow numbers I have show the stock heads at 183cfm intake and SoCal stg2 in the 230cfm and the Bromax Stg2 heads on my truck are in the 290cfm range. The big difference is how much airflow is increased at a lower lift of the cam vs a stock/ported head. They will only get better with time. They will hopefully be ready to bring to the market very soon!
paint94979
Beer Nazi
Sep 18, 2006
11,742
33
That's great info Mark thanks for sharing
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
central Ohio
Heads
Its good to see brodix getting into the market. They always have a good casting that people can work with. I also think to most have no idea the level that Guy Tripp brings to the head market! He has forgot more than most of us will ever know. He has been at a very high level going back farther than most have been alive. LOL :hug:
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Who says what after market heads "SHOULD BE" A guy can make a decent buck and not gouge people.How is it you can get a set of BBC after market rods for 4 to 600 but someone makes them for the diesel market and they are 2600?And yes in the beginning prices are a bit higher to pay for production and development but man 6500 limits you to the top 1/2 %of the diesel world......the top pro racers.This is only my oppinon, I still can't wait to see what these will do but as much as I would love a set I will never have them.
Eh this has been discussed to death as to why Dmax parts cost what they do it's very simple. Using your example how many BBC are built being built and CRATES of rods sold compared to Dmax motors? It's probably a 1000 to 1 ratio! Heads are probably worse in actual numbers sold. I'm sure you know this anyway your're just stating your diss-like of the price . :)
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
66
Norco CA
www.mcratracing.com
It makes a lot of sense. Big nozzles have issues at low boost, so run a set of little uns and biguns. 800rwhp out of the little ones, then big ones should be able to add 1200 more at least.
1slowmax
The break is over
May 9, 2012
283
Sin City, NV
I think they should have shitcanned the glowplug and figured out how to put in a second injector ...
EXACTLY!!!
My good friends Supra makes 1400hp and it runs on 6 injectors up to xx amount of boost then the second set of 6 injectors kicks in for a total of 12 injectors. I thought of this for the Dmax and it would be very very smart but could EFI live support the tuning that would be needed? Im sure it could be figured out but its all just $$$$$
ryan415
Oct 24, 2012
371
860
EXACTLY!!!
Nelson Racing uses a similar system with 16 injectors on they're twin turbo motors. Basically has two fuel systems. Primary injectors run pump gas while secondary injectors run race gas. Pretty cool setup
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
42
Des Moines, Iowa
EXACTLY!!!
How hard would it to do a set of IDI injectors in the intake runner like in a Gas EFI lives setup.
F
Fahlin Racing
Guest
Just wait until the Dmax head is being produced for a while & by multiple manufacturers, the prices will lower to compete for our business.
15,681
236
Won't these new heads have to be reworked? $$$$$$$$$$
I bet if you install them as is they won't flow as much as a custom stock head. So now we are looking at 10K for a good set of heads.:dontknow::eek:
