282
Well what I consider a "complete door" is isn't the same thing at his place.. got ~75% what I need,
All that was gone did get electrical harness and almost complete PS door
282
Got doors home, I've got the tan bale connectors in my truck but not the purple center connectors. I've done some digging but not through looking for them.
DS has two PS has one connector.. which I got no idea what they control, keyless entry maybe?
DS need inner door panel and master switch with bezel.
1,738
Can you do a better picture of the connectors so I can see the wire colors. Maybe I can find them in the schematics.
Another possibility, is the two doors from different audio options like luxury, bose or basic?
282
Here, also vin from donnor
The wires these were connected to ran down under door sill
Probably need to get a subscription to all data again
1,738
I couldn't find any exact matches in the diagrams but it did look like there was some difference if the mirrors where heated, and had turn indicators. Also for the auto windows, and audio system. But couldn't find any concrete schematics that had the same color wires with the same type of connectors
Reactions: malibu795
282
I should have snapped a picture of the rpo list when I was down there.. hopefully windows and locks go through the bale connectors, as I'll use those more than adjusting my mirrors.
I'll swing by local dealer to get a print out on the way home tonight.
Most like get shelved till truck is running
And I'm not going back to the place I bought the doors.
815
07 and 08 are like bastard years on those trucks...
Any way, I think that's an AN3/ DL3 optioned truck. What looks like Orange I believe is actually supposed to be red. My dad has an 07 and remember having this issue trying to follow the factory manual when diagnosing the switch for the window not going up and down.
And FWIW a brand new switch has to be programed with GDS in order for it to work...
  • 2007 power window.pdf
  • 2007 power locks.pdf
  • 2007 power mirror DIAG2.pdf
  • 2007 power mirror DIAG1.pdf
815
I think I found those 2 connectors, check this pin out.
  • 2007 Left front door to body harness 1.pdf
  • 2007 Left front door to body harness 2.pdf
282
Got rpo list no AN3/DL3 listed.
Have A31(P/W) and AU3(P/L) and AP8 extended range keyless entry
UQ3/US8 is radio/sound system.
Only rpo codes related mirrors is the inside DF5/DH6
Unless outside power mirrors are buried in the 1LT option 1 package?
