I think I'm passed that part, who came up with that idea?I tried to stave off hub replacement by the "shoot a little grease into the hub thru the ABS sensor hole every year" method from back in the DP days.
I've had that happen before.I just replaced all 3 of my idlers and tensioner pulley. Still have squeak. Think it’s the alternator.
In the spirit of tommy boy, why is your wheel bearings better? Besides E-coating
Thanks
Well you can stick your head up a cows azzBeen getting flooded with axiom supply parts, so I sent them an email...
Now I wait
I didn't skip either..SKF, OEM GM (not ACDelco) or Timken, in that order......Hubs are one thing I do not skimp on.
No Detroit Axle, No TRQ!!!!
ON EDIT: Oh hell no! Axiom = Reseller. But $259 for an unbranded hub?!? SKF are $180 on Rockauto, $213 on Amazon. Timken slightly cheaper.
Per Tommy Boy;
“Well see, a lotta wheel bearings out there, they look fine. Real shiny. Real confident. But that’s like saying you’re a great salesman because you own a tie.
Here’s the deal.
Axiom bearings are built with premium bearing steel—the kind that doesn’t panic under load. It’s properly heat-treated so it keeps its shape, keeps its hardness, and doesn’t turn into scrap metal the first time you tow something heavier than your buddy’s jet ski.
Then you’ve got precision-machined internals. Tight tolerances. Everything lines up the way it’s supposed to. That means less wobble, less heat, and way less friction—because friction is basically the silent killer here.
And now—this is the good part—the friction-resistant internal coatings. These coatings reduce metal-to-metal contact, protect against wear, and help the bearing survive long after cheaper bearings have already punched out. Less friction means smoother rotation, cooler temps, and a much longer service life.
Top that off with high-performance, high-temperature grease that actually stays where it belongs, keeps lubricating under stress, and doesn’t give up halfway through the job.
So yeah—other bearings might spin fine on day one.
But Axiom bearings? They keep spinning when it actually matters.
Because if what’s inside the bearing fails… the rest of the truck is gonna find out real quick.”
lolSeriously though, we provide premium parts and top quality service behind each of our parts. Please let me know if you need any more help!!
Figured most of that was copy n paste..That's the most AI response I've seen from a company all day. Sigh.
Sent from my CPH2655 using Tapatalk
I have a set here and can shed some light on that. They use an incredibly high quality bearing (think old Timken level of quality), high quality grease, very nice sheathed wheel speed sensors (almost feels like a very pliable silicone sheath).Been getting flooded with axiom supply parts, so I sent them an email...
Now I wait
Personally I would say yes based upon my existing usage but I don't have a 10yr track record with Axiom to 100% say that. They're trending that way but I think it's too early for a definitive answer.@Bdsankey are they SKF level? Or yet to be seen?
IDK if Napa is going to warranty the 2nd bearing.. though they claim the 3yr warranty resets with the new bearing
I did ask who they contacted to make the bearings
