I found the correct terminal tools and swapped pins, super easy and very clean looking!
Where can I get the tools? Thanks.
Is it a weatherpack?
Does anyone know if the firing order for the socal cam and empire cams are the same? Anyone have a pin out diagram for an lly ficm? Other than tracing injector wires back to the ficm connector, I don't know what wires are for what. I'd like to swap wires rather than cut and splice.
http://www.vehicles-classifieds.com...6030-12pc-Terminal-Tool-Kit_181601479567.html
This is the terminal kit that I used, one of the terminal tools works with the larger wires 2/5 and 3/8. The smaller double wires 6/7 and used a very small safety pin to release them. Everything worked out awesome and not cutting wires!
Does anyone have the repinning instructions for lmm? My socal came didn't come with anything. Thanks a lot
they can explain it Does anyone have the repinning instructions for lmm? My socal came didn't come with anything. Thanks a lot
Talk about reviving a post, the last comment before yours was in March 2015 (almost 8 years ago).I recently repined my ficm with socal instructions and they seem to be different from Wagler for 6& 7 the blue and white and red and white wires are the only wires in different spot and when I move tried moving wires from hole to hole nothing happens. it is running bad and seems to be getting to much fuel, any help would be appreciated
I just now looked at the dates haha, and I’m using a socal stage 1 and can’t seem to get it right, every injector I unplug shows a different cylinder then the stock fire order or the alternate fire order. And the fpr command rates are all over the placeTalk about reviving a post, the last comment before yours was in March 2015 (almost 8 years ago).
Lets start with what cam are you using?
Bust out your multimeter and trace/ohm the wires so you know exactly what goes where then make your modifications. It sounds like the wiring is not correct.I just now looked at the dates haha, and I’m using a socal stage 1 and can’t seem to get it right, every injector I unplug shows a different cylinder then the stock fire order or the alternate fire order. And the fpr command rates are all over the place
