Ok where do I start…I started with a bad #7 Injector; where I busted the FPR Sensor, Replaced that…drove fine for 2 months, then started throwing a P0087…Service Bulletin about Collapsing Fuel Lines; Replaced all the FEED LINES with the Parker Hose recommended…STILL THROWING P0087…Replaced the Filter Housing…STILL HAVE P0087
*NOTE:
The Manual Prime is completely SUCKED DOWN!!
I drive about a mile, FINE, then I get “Change Fuel Filter” then IMMEDIATELY “Check Engine” “Reduced Power”—-then it STALLS!!
I get out, pop the Bleeder on the Filter Housing—and—HISSS—-UNDER PRESSURE—-PRIME KNOB IS DEFLATED—NO PRIME—
I have to MANUALLY PULL THE PLUNGER UP—EACH TIME to PRIME—-
CLEAR CODE
STORY STARTS ALL OVER!!!
WHAT AM I MISSING?!?!?!?
ALSO: I have an AirDog Raptor 4G 100 being delivered on Tuesday.
*NOTE:
CLEAR CODE
