2002 LB7 Fuel Leak by Cooler
SmokeShow
6,818
Lawrenceburg, KY
Finally finished the power steering hose & hot side intercooler pipe replacement and new shocks all the way around and upon wrapping up the rear shocks yesterday, it was noticed that the truck has sprung a fuel leak. It's leaking where the braided hose crimps to the hard line near the fuel cooler. Is this a known issue where there's upgrade parts to put back in their place (like the power steering hoses), or just cobble some new fuel hose in there with adaptors from hard line to flex hose? Really want to avoid dropping the tank or removing the bed because the tank was literally just topped off Sunday and I'm not 100% sure I'd be able to get the bed off due to a stuck "turnover ball" gooseneck hitch. What are my options?
DuramaxRamRod
168
22
MI
Clean the rust off and cut the steel lines and pull the quick disconnect fittings off the cooler and run rubber lines with hose clamps. Thats how I fixed my Dads LB7.
DuramaxRamRod
168
22
MI
I'm sure there's a better fitting but I just put the hose on the tube with a hose clamp. Didn't want to buy new lines or replumb everything at that time.
SmokeShow
6,818
Lawrenceburg, KY
You can buy tube to AN fittings on summit and replace with new 3/8 braided line if you want.
This is more the route I'd been thinking of taking if it doesn't require a flaring tool or anything since I don't have one. I suppose I could buy one to have for any such occasion in the future. Always a good excuse to add some tools to the stash. (y) Then I'd just get a straight/inline pushlok fitting for tying the new hose into the existing hose.
ZeroGravity58
1,420
54
Maryland
I've used these on my truck then use regular hose ends to make up the piece. The only thing is sometimes it take a little work to get them to seal on the steel line but they will. To me they look better then rubber line. Not that anyone will be seeing them but I'm picky
SmokeShow
6,818
Lawrenceburg, KY
Digging on Summit last night and I tried to put together a setup like that but I wanted a pushlock style barb to put on that fitting and all the barbs were too little that would thread onto it. I've not bought a lot of fittings in my day. I feel like it'd be 1000x easier if I could go put my fingers on them and pick them out rather than making sure I'm putting the right combos in my cart online.
There was (1) 3/8" brass compression fitting for the tube side with a 3/8" hose barb (regular, not for push lock). But all the reviews said the bard was actually too small for 3/8" hose so thats a no-go. Bummer because that's almost exactly what I wanted.
And slightly off topic... I guess I'm a complete idiot ?‍♂️, but I never knew "AN", as in AN fittings, stands for Army-Navy. Mind blown ? when I saw that spelled out in a description on Summit Racing.
13,862
966
If you cut the crimp collar (being careful not to cut into the tube), the tube is already flared for the hose. You can just push new hose on and clamp it.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,886
801
Central OH
I find it much easier to get on Holley's website to look for fittings. Using Jegs or Summits website can be irritating if you're looking for something specific
ZeroGravity58
1,420
54
Maryland
I agree I miss their old sites, to me they were so much easier to navigate. Half the time I can't find what I'm looking for and go on Google and search it pops right up on their sites....
turbo_bu
199
7
Central IL
So I looked at my 04 and noticed some pretty crusty connections down at the fuel cooler end. I am wondering how guys are either fixing those ends, or are they just replacing the cooler?
SmokeShow
6,818
Lawrenceburg, KY
the crimped collar plus about 3-6” of line is crusty. The rest of the tubing looks basically new. So cutting them back a little ways from thejunction is going to be necessary.
