Sub'd
Sent from my SM-G925V using Tapatalk
My father in law bought a 86' 3/4 ton with a "built 327", he drove it a month fine, I took it for a drive after we lowered the lift from 8" to 5" and do what I do best, lost oil pressure at idle, started knocking, I spun the rod bearings in it, so I pulled the oil pan for him and found some Scott shop towels stuffed in the oil sump, new age internal oil filter I guess. Should have seen the lift too, wish I would have got pics.
Told ya this would be a hit, I enjoy getting the WTF pics!!!
Caleb did a set of LB7 injectors for us couple years ago and found a single piece of 2B limestone under the valve cover, laying off by itself in a corner of the head.![]()
That's the same leveling kit I just put in my super duty haha.I'll play.. 7.3 im putting a trans in today..
:thumb:
So it's a legit kit?
Friend sent/tagged me in this.. I've seen 4wheelers TRY and do this to regular trailers...
Got this awesome muffler delete into the shop today. To top it off I believe the guy was even a welder. Had a welding sticker on the side of it.
Just because you have a welder doesn't make you a welder, haha. I guess the same goes for anything. Just because you have a toolbox it doesn't make you a mechanic. Just because you have a bulldozer it doesn't make you a grader, etc. Wonder if this was one of those "that's close enough we'll caulk it" scenarios?
