Timken! Got mine at Rock Auto, best price at the time. I don't remember how much though....
What's your zip code?
Good to know.. Check mine as wellThere is nothing wrong with SKF in my opinion. I have even seen them in oem GM hub assemblies.
Just for the record. The difference between the SRW and DRW front hubs are the studs. The SRW have an extended non threaded section for starting the lug nut. The DRW are fully threaded for the bolts that hold the adapter on and shorter on the stick out from the wheel mounting flange. I ordered the DRW by mistake and did not have time to wait on the replacements, thread pitch on the studs is the same.
haven't pressed to find the c0131 code since it doesn't trip the light
well thats because its for the trailer brake control system. not the ABS.
google it.
Ahh the POS crap that couldn't properly apply trailer brakes and thus resulting in almost 3 complete jackknifes. Which resulted in me splicing in a complete stand alone system with a P2
yeah, it was probably not applying correctly because it had an intermittent problem with the pressure sensor. DUH.
