#%#&$-# abs
1,456
Just got truck up and running got a well paying money load and this ABS light comes on... It's a DOT violation if caught.. So I backed out..
This trips when truck is moving
This will trip when truck is sitting still but not trip the ABA light... Truck is not equiped with traction control..
Checking connection.. Hopefully the ABS pump ain't going out..
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
My dually gets that while sitting still....
Goes away without going 40mph too
Got the module at home to replace it, also try cleaning the grounds under the drivers door
on the frame
1,456
on the frame
I'll check said ground... Originally the code was just the wheel senseor.. The tripped back when the block broke last time...
Does it at all speeds on mine
Said ground was fairly rusty... Test drive.
Edit #2 still there
8,050
Can you hook a scanner up that logs wheel speeds at each corner? Don't remember if efi live can but I think so
1,456
No it can't.. Did find out c0035 is left wheel not right... I disconnected right and c0040 came then went away after I reconnected it..
Also found that the wheel sensors tend to go out when wheel bearings start failing....
Lifted left wheel... Found good 1/16-1/8" slop at top of the rotor... Bearing is shot with almost 266k on it
clrussell
pro-procrastinator
Sep 23, 2013
6,034
527
Sounds like you found your problem
9,963
236
That's 3 times the mileage I got out of the d/s wheel bearing on my truck. I'd say you had a good run.
Sent from my D5803 using Tapatalk
8,050
That generally happens unless you have the Chinese wheel bearings, then the whole hub just snaps and scares the shit out of you at 70mph
