Pre cooler temp is the hottest you will see. Pan is coolest. I know this from putting the probes in the wrong area![]()
They should be close, if not the same. Where's the first place oil goes after soaking hot engine parts? The pan.
Sean.. I avg 120-130° above ambient temps.. Highsail loads and head winds can easily tack another 20-30° on to that spread.. Even with slowing down. It has at time gotten to a point that I park it for the day and finish the run at 2-3am in the morning
29 psi
Mat (nwpadmax) proved that, while thats the case when the system and oil are cold....at operating temp, they spray pretty much constantly.
http://www.dieselplace.com/forum/3-...e-discussion/151060-lets-talk-pistons-18.html
Ben
Ben
What were your oil temps when the pressure would drop to 30 psi?
220+ when below 1800rpm basically 5th below 65 mph..
Just found out my mains need honed.. Logic would say increase/warn bearings had a hand in dropping oil pressure as well
id say so as mine doesnt see below 45psi at that rpm and temp.
Same with mine. Where exactly do you have your temp sensor installed? I wonder if your gauge is giving a good reading.
coolant mixed into the oil and rod/mains self clearancing, i can see it hitting that pressure at that temp.
