Im just saying I know the stock ported could get 270 but they wouldnt last long
How much are the valves? I see the bare casting and CNC ported castings say the come with guides and seals. I can't find anything on the valves though. Anything in the rocker assembly need changing since the valve centerline is moved alittle bit?
How much lift can we use? When is coil bind?
How many sets have cracked Wade?
Not saying it hasn't happened, but I don't believe I've heard one concern on the valve reliefs getting too close to the ring lands.![]()
The little bit I know of them they have had some problems with them cracking and the valve seats coming out of them. I'm really surprised because is a very good company! I still haven't seen any earth shattering power out of these vs a stock ported head. I just put a totally stock set of heads on my dragster motor (other than springs and retainers) and will see how they do vs my old SoCal heads.
Yes wade, where are they cracking? They have thicker decks, better cooling passages so what is making them crack? Interesting.
Something to do with the manufacturing process
For the record, I was being genuinely curious. I hadn't heard about the cracking issue until Wade's alter ego brought it up. To be honest, I did get a couple e-mails and phone calls yesterday explaining the issue so it's not him just spracking off like I expected.
Boy you really got it out for him, dont you? Anyway the issue has been talked about in various places including "Wades" shop, to the best of my knowledge the failure is between the exhaust port and glow plug hole.
No I don't have it out for you "Wade". The few transactions we've had have been somewhat pleasant but your internet ego and persona extend beyond a username. Just figured is call a spade a spade.
No I don't have it out for you "Wade". The few transactions we've had have been somewhat pleasant but your internet ego and persona extend beyond a username. Just figured I'd call a spade a spade.
I'm not much of a debater, so i'll get right to the point:
You elude to the assumption I'm "Wade" because I use and support products of his. Or, Your calling me "Wade" because I seem like a mouth piece for him. OK guess I should stop sending in my taxes to the Government because i'll be called Obama next... Great thought, but flawed logic.
Most diesel heads are 48" vacuum flows... Including SoCals on the bench I seen... Because my SoCal stage 2's were nowhere near the 260ish claimed...
