VS built 7.3
NinjaMax
WTF!
Oct 3, 2012
1,266
41
Severance, Colorado
My truck..epr S475/stock..ATS trans, fass 150, 4:56 gears on 37's, kryptonite stg 3, cognito bars and braces
Vs
2002 EC/SB 4" lift on 35's. He's got a pretty healthy list of mods..I know he's having a little trouble lighting her up but here it is
130 over injectors, powermaxx gtp 38 r Garrett ball bearing 88mm turbo, decked the heads, ceramic coated pistons, ts performance matched chip to injectors and turbo, 4 in exhaust, bigger intake valves and heaver Springs
bigjake18
85
college station, tx
7.3s are still slow. He has a lot more weight than you. Don't spool up just ease into it till you know you won't spin and hammer it. Soon as your turbos light you'll pull away:D
TLyons90
Apr 22, 2013
1,631
Greenville, SC
Like everyone is saying you should take the cake! If you cant run him in 4wd just tell him a 2wd roll race from about a 30 and if he is having trouble lighting up his setup you will have no problem what so ever pulling on him from a roll!
BLACKMAX1
WAY2EVL
Jul 10, 2013
555
VA beach
Yea from a roll would be sweet, you can hold the brakes a bit to bring your rpm up but shouldnt have too. You'll have no problem beating him. Take a video :thumb:
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
A 38r turbo spools faster then a stock 7.3 one. They are good to the 500-550 range. I have never heard of 130 over injectors. Most guys go by cc's and nozzle percentage. Either way he dont have a chance.
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
39
Houston, TX
From a roll is fun if you have a lockup box... Little brake boost to spool her up and as soon as you nail to go it the box will lock and "she gone"!! :woott::D
You have to make sure to manually put it in a lower gear so it does fall under the power curve when the lock up box locks. Just depends on the mph/gear.
Not sure if this is frowned upon or not but it flat scoots! The boys down here with manuals always want to run from a roll.
NinjaMax
WTF!
Oct 3, 2012
1,266
41
Severance, Colorado
Yea no idea..that's a copy paste from his text...looks like as soon as the roads clear up its go time:D been months of shit talking leading up to this. :woott:
Jackblack99
Oct 18, 2012
270
Nowhere
He clearly doesnt know the mods to his own truck. Like stated above ford injectors are rated in cc's the nozzles are % over stock. Like my old 7.3 had 250/100's. 250cc's more than stock and 100% larger than stock nozzles. And a 38r is t an 88mm!!! My truck also had a 38r... Its a 66mm inducer. The exducer of the comp wheel is 88mm
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Not to mention over sized intake valves.
