I believe that 600 is safe with injectors, my tuner said 650 is safer on a stock Lbz motor with nozzles than 600 with stock nozzles
you got no room to talk. Jason just posts his questions here over and over a few times instead of calling everyone in his contact list a few times over with the same question like a certain someone does :rofl: :angel: :hug:
I think you all are nuckin futs with your "700hp on stock motor" talk. Have fun with your rebuilds.
I know starlite is a respected tuner, but IMO that advice is just plain irresponsible. You guys all need to dial it back a bit. Just b/c one truck did something doesnt mean they all can.I believe that 600 is safe with injectors, my tuner said 650 is safer on a stock Lbz motor with nozzles than 600 with stock nozzles
Kid, it just is.How is that advice irresponsible??? I didn't say its safe, just safer than 600 hp with large pulse
All dynos read differently, so don't go off of that. Go off of trap speed vs truck weight. Bigger injectors are good for making a big number on the dyno, pushing more fuel for that short pull, but a full run down the track you will drain them for sure. Generally, stock cp3's are good for 600rwhp, +/- 25.
Sent from my iPhone.
Kid, it just is.
Don't call me kid, and so your saying 600 hp with stock fueling is safer than 650 hp with nozzles?
"Kid" is accurate, and a hell of a lot better than some other things I could've said.
Neither 600 on stock injectors or 650 on larger ones is "safe" by any means. Im damn tired of newbies coming on here and "promoting" higher and higher numbers as "safe".
I still have a lot to learn but isn't it the torque that takes out rods?
Cant you control torque better by being able to control your pulse width with bigger nozzles?
I'm a newbie? Okay bud whatever floats your boat.
I never said it was "safe" I was making the statement that 650 is "safER" with nozzles than 600 hp with a lot of timing and pulse.
