Lml pistons are already in high horse trucks Fwiw.
Are you sure......???
You cant just put LML pistons on off-the-shelf carillos/crowers....so those "high-horse trucks" must be running LML rods too.
I may be missing something in the thread, but.....How will you be tuning this truck?
Now drive it like it's a customers on a test drive!!! Dounut shop here we come.
LML approximate prices from the dealer
Rods $45 each
Pistons $23 each
Rod bearings $5
And no, there would be no additional machine work involved. You can drop a LML piston and rod into any duramax, you cannot put any piston but a LML piston on a LML rod and vice versa.
Why do they have to be off the shelf rods? Camomax posted in the monotherm piston thread DTS has two LB7's and a LLY running LML pistons on carrillo and crower rods.
Off the shelf carillo/crower rods wont fit on LML pistons.
I wish lb7 pistons were that cheap
For those needing some numbers I did some digging,
Rods- 980627987
L Pistons STD- 19256948
R PistonsSTD - 19256949
OEM rod bearings- 97250338
I was quoted 65.76 per rod, 23.39 per piston and 8.65 per bearing, total with tax would be 851 :spit:
