Here's my question:
How much water can you spray? We run about 1 pint per 10 seconds. That's a maxed out Snow system.
that's about 1 lb or around 1000 BTU in evaporative latent heat consumption, or a rate of 360,000 BTU/hr. That's about right for all the induction heat you are creating, but if it is all post-compressor, your evap rate is a speculative 10%. So mostly all you are getting from it is egt reducton plus a bit of fuel value (if meth mix) and a great cylinder steam clean. IMHO, you need to route 70% of this flow to pre-compressor.
But it is a great question with lots of answers depending on who you talk to. My approach is much different than most others, and involves psychrometric charts, MAF and saturation calculations. Good for another thread.
How much boost/rpm are you running on your stock turbo?
If your asking me, with my tow tune, I run a max of about 22psi and the average at 1900rpm is about 5 to 10 when towing 9000lbs.
My race tune runs uperwards of 28 if I am lucky and shifts at 3700rpm.
I have a hard time building boost at the best of times, but no problem building egt's!!![]()
never thought I'd see that word again after the class.
No issues with my labonte kit and I fill my 5 gallon tank up once a week if i drive every day, city and highway traffic.
Pat, you asked how much can one inject?
On the back of my nozzels it says "M8" and "M12"
I called dan @ labonte up and he told me with the 250psi pump that I have all full boost it is flowing 800 ml/min and 1200ml/min.
That is A LOT of water...
Im not 100% sure that what he told me is true or not, but It does seems like I use more water/meth an everybody that I have talked to..
.........You have a hard time building 28 psi? You shouldn't. 35 psi is very achievable if there are no leaks.........
You would think so, but I think I spiked 30psi once or twice when I was in Cali, and the rest of the time I am lucky to get 28 in 3rd or 4th. For some reason, this truck has NEVER been able to build much boost. And believe me, I have tried many different tunes to try to make it happen.
But this is OT.
Since you
have a LBZ you should be able to hit 35 like nothing. Maybe next time you are in Edmonton or I am near Red Dear I could take a look.
