JoshH put a hole in one of his pistons after twins IIRC.
Josh ran his truck hard before the twins though IIRC, whereas [Idaho] Rob didnt even put a tune on his truck until the twins were on.
that makes a huge difference IMO
ben
The highest timing I ran with the bigger injectors was 26* and that was only from 3250RPM and above. When you only have a 1960 PW you don't need much timing to get your fuel shot in.
That is most definitely a modified piston. Looks like it might be delipped, but it's hard to tell without seeing better pics of the bowl. At the very least, it has had valve reliefs cut into it. Not sure if it is coated or not. What I can say it is without a doubt is an LBZ piston, not an LB7 piston.I don't know hardly anything when it comes to pistons.... My buddy gave me one and said it came out of a very fast duramax that likes a ridiculous amount of nitrous. Any idea if this is cut/coated/delipped or any of that stuff previously mentioned? It looks pretty interesting and has seen better days.
ben
Josh also ran 5-30w oil just prior to the cracked piston. On a hot day his oil pressure was dropping below 30psi.
nathan was it 5-30 or 5-40??
I run 15-40 and my oil pressure is still only like 23-ish psi hot at idle.
this is an LBZ shortblock/oil pump
my original LLY had the same oil press as my current LBZ shortblock
my built motor had a little better; maybe 28-29 hot at idle. Then it broke one of those POS rods and had 0 psi oil pressure.
ben
I don't have any data. I got my gauge about a week before I parked the truck for the teardown, and I never got a chance to install it.My queston to you josh would be what have you seen since you started monitoring oil temps , how hot have you gotten them and what has had the most effect on getting them hot , racing towing ect . ?
I disagree. I decided I was going to put it after the cooler because I wanted to see the temperature of the oil going to the bearings and pistons. If the heat is causing an oil pressure drop, it will show itself after it goes through the cooler. I want to see if the factory oil cooler is sufficient to keep the oil cool in high load situations. I know the pan temps of the oil will go up in a high load situation, but I want to see if the stock cooler can cool it back down. Also, I was contemplating putting an external cooler on the truck, but I wanted to see what kind of post cooler temps I saw before and after. I figure if the stock cooler can keep the oil temp after the cooler at or below engine coolant temps, an external cooler won't really benefit me any.Josh measures after the OE cooler, so his number isn't a true oil temp...IMO
1960us to go low 12's??? Thats a lot bigger than "90hp" injectors.
