Pics of Suspension Stops
WanaDmaxsub
Junior Member W/gray hair
Feb 17, 2007
644
Here's mine.
But, I didn't make them.
attachment.php
Josh2002cc
That Uncle
Apr 2, 2007
1,832
39
My god that is stout. Looks good though.
One question, why is the stop itself touching only the u-bolt? Perhaps that is normal I really don't know.
13,599
633
I think the camera angle just makes it look like it's touching the U-bolt.
jneal
Feb 12, 2008
294
Bloomington, Indiana
I've got the same ones a wanadmaxsub and they work great, bolt right in. I've got 2 seasons on them, only thing I have had to do to them is I took them off last week and sandblasted and repainted them. They look good as new. Alos the way they are designed, you can adjust them in 1/4 inch increments by flipping the stop block over and by using the 2 different sets of holes in them. For what it would take to build a set similiar to these, you're better off just buying them from Tony B or Danville, but that's IMO.
cuminstrkmydmax
Sep 10, 2008
223
North East MD
I will post up picks as soon as i finish welding them up- I am using 1 1/2'' sch. 80, two 1'' nuts, a piece of 1'' all thread rod, and two pieces of 1/4''x 2 1/2'' plate. They will be adjustable to the 1/16'' , and strong! They are pretty simple to build as well- only requires drilling two holes to bolt it into the stock bumpstop position.
THANKS Steven
ChevyDealer
Dec 12, 2008
21
Missouri
Here is what I have been using for awhile. These are my 2nd generation and final generation. I really like the ability to screw each of them down to a 1" spacer (wood block) and lock them down.
Craig
P.S. I guess I'll add pictures after this post since I have to have 10 first.
JMK777
16's, but i keep em clean
Mar 20, 2008
1,433
Moss Beach
here are mine. they are machined out to miss the pin in the leaf spring.
durallymax
Apr 26, 2008
2,756
Under The Hood
I must be an odd ball. I made mine to bolt up to where the bump stop was and contact the pad on the axle tube.
Im working on building a different better set though.
WanaDmaxsub
Feb 17, 2007
644
Would it be better to use a bump stop or something? Seems pretty solid and it would slam pretty hard??
You want it solid. Other wise it could bounce (hop) which is a bad thing! The weight comes on slow, I've never felt mine slam.
Looks to me like those of us using a side mount is because something else is in the way. For me it's the air bags, i see traction bars in another pic.
