So, on a motor build, what needs to be done? I know this has been covered before in threads, anything all inclusive though? Anyone know of some sort of step by step? Forgive me for not searching, Im a little upset at the moment.
Well first you want to pull the motor and tear it apart:angel::joker:
Then after you see the damage, and whether your block is still usable decide what you're gonna do. Build or find a cheap stocker.
Order the parts from Guy @ SoCal, send your block out to be machined then put it all together.
There is a lot of data that Henry has posted here with specs, but we used alldatadiy.com for more/other info we couldn't find.
IF you have to get new pistons is going to be a killer.. if you can stay std bore i got a pair of LB7 (std) pistons that are in good shape mat..
cast piston, billet rods and main stud, deck, line hone mains, and bore/hone block. that will handle 800rwhp easily
IMO main studs are a waste of $. Especially under 800 hp. When I have seen proof of cap walk then I will say you need studs AND steel main caps or a girdle. Pretty hard for a cross bolted cap to walk if its not flexing. And if it is flexing bolts aren't going to fix it
When we took Tommy's block and some parts to Guy he showed us where it had already walked a little bit.
I would like to see pics of cap walk. I have always belived in doing steel mains or a girdle with main studs. In all motors I have seen studs did very little if not nothing without better caps. Studs can't stop the cap itself from flexing. JMO
Well I don't have any, but the studs do help to an extent imo. After that there is also billet caps for our trucks
I agree with Lonnie on the caps. The cap is only so strong. With a cross bolted main i'd think it would be hard to better it. I think girdles are a band aid but thats just my belief. Jeff
Im more worried about the machine work and R&R of the engine then I am parts or the fundage. No good machine shops around here that I know of, so everything is gonna have to get shuttled down to SoCal and back. Im not sure if I trust myself with assembly either, which means the added cost of having it all assembled
If the motors happy you wont have any problems unless something goes wrong. Jeff
You know, Kinda like a wife! Jeff
