Hello, anyone have a source for the o-rings for an HSP compound kit? Apparently they no longer do.
If you know the dimensions, mc master carr has just about every conceivable size in multiple materials and hardness you could desire
Also, theoringstore.com can get any size you need
I don't recall ever seeing a square cut o-ring in an HSP kit. Are you sure it isn't just flattened with time and heat exposure?
Also, with an OD of 4.133 and an ID of 4.088, that would give you a cross sectional width of .0225 which is incredibly small. You sure about those dimensions? Where is this o-ring going? Is it on the flange that seals the cold pipe to the inlet of the stock turbo?
Sounds like a standard 241 o-ring.
Supposedly the lower Rad Hose could have 2 different sizes.
Smaller sized one is a 226 size 70 durometer red o-ring .139 cross section
The Larger fatter is a 329 size 70 durometer red o-ring .21 cross section
On the cold side pipe, I'm not sure of the size. All I could find was the part number GM 19121496. Takes qty2. - 1 on top & 1 on bottom.
