? You May be right, we May be crazy...? -- May '25 Chat
I loved it as a kid. Still love it today. I remember having friends that were scared of it. Couldn't understand why. I remember asking them how could it harm them or do anything other than make a light and noise show. Their answer was always a vague "it's scary". Always baffled me why anyone could not enjoy it
N2BRK
2,393
733
I used to love storms. Living down the shore was a treat, because we’d get some whoppers! Now that I own a house, I’m not so much in love with storms.
1,514
Bought a new dryer today as they're on sale..
As if electric isn't confused enough..
It's been my understanding the ground is not counted in the wire strand count.. 12/2(3 wires) 12/3(4 wires) seams with it comes to ranges/dryers... It's not??‍♂️?
Anyways
Going to feed my 10/3 dryer plug with 8/2 wire from a 30A 2 pole breaker.
IMO pending the length of the run.. 10ga is too small for a 30A system. But seams society says instead of going one size bigger we'll add another wire??‍♂️
Anyways
I would be surprised if your dryer didn't have a separate ground and neutral connection. Most older dryers (and ovens) had bonded ground/neutral connection right at the cord connection. But from my understanding this is not code anymore. In addition to the safety concerns, it can create ground loops with the bonding in the main panel
But the newer ones almost always come with a means to bond the ground to neutral and use the cord with two hots and a ground for grandfathered homes
The naming of cable, such as 10/3 normally doesn't include the ground in the numbering as it's assumed to always exist. But there is no code or regulation for this so depending on brand it can vary. Some will actually say "with ground". While others add it to the numbering. Always good to read the description or inspect the cable before hand
1,514
Dryer is capable of 10/2 or 10/3 hook up.
Yes Ground loops can easily cause problems. Adding a second return line whether one calls it a ground or neutral.. doesn't help the situation ..
Seams code after 96 they're supposed to be 10/3 power supply. Yet both the neutral and ground are connected in the main box...
My gripe is stuff isn't labeled consistently... Which can cause problems.
I highly doubt I'll have any problems with my shop dryer.
N2BRK
2,393
733
Old 240v dryers just needed 240v, and that’s made from two 120v wires and a ground just for safety. Modern dryers have all kinds of electronics now and need 120v to run them. If it has a transformer built in, then you could run it on a two hot and ground setup, but if not then you’ll need to pull a neutral for it to use. You don’t want to try to make 120v by grabbing one hot wire and using the ground wire.
1,514
It works very well on 2 hots and a ground.
I posted a link to what I bought
darkness
1,586
612
vegas
SO/SJ cable almost always counts all the wires as conductors. While MC cable counts line and neutral as conductors. Here’s examples of what I have laying around in the shop.
IDK if I own any cooking stuff with Teflon coating, generally use bare stainless steel, though im slowly swapping to cast iron.
Same here. I mostly just have one non stick pan now I use for scrambled eggs. Still haven't got the stainless down for stick free eggs. But almost everything else is in stainless or cast. Not that I'm really trying to avoid Teflon, it's just the short life and constant replacement that's is starting to get to me. Stainless and cast are life long investments
Pure Diesel
989
301
Ventura County
Any of our Teflon kitchen stuff all I use are rubber spatulas or plastic. I never use anything metal to scrape or scratch it.
