LMM: Lmm dsp5
joshgabel
Oct 24, 2014
11
Liberty hill tx
I recently tried it. not bad. i will say my idaho rob tunes are a little more refined but this tune pack is pretty damn good. and you cant beat the price.
303nelson
Dec 31, 2024
canada
Hey, came across this tune the other day and downloaded it onto my AutoCAl. Want to use it on my truck but I’m still pretty green at this whole tuning thing. Couple questions, I can still use this tune and switch between them without a switch by using my efi live correct? And what’s the deal with this VIN license stuff I hear about? I found on the v8 where I can change the controller vin but is that good enough or will it bugger up my truck somehow if I don’t get this VIN license. Thanks
3,058
You'll need a V2 or V3 to use the tune. An autocal is linked to a tuner and can only use their tunes
3,886
801
Also if the tune was setup to work with a switch you'd have to change it to serial data to change tunes with your autocal. Like Jason said, you're basically up schit creek with an Autocal
13,862
966
As previously stated, you cannot load one of these tunes with an AutoCal unless the tuner your device is linked to sets it up for you. Also, serial switching is only available for LB7/LLY trucks. LBZ and LMM need a hardwired switch.
3,886
801
Ah, yes. I knew that you couldn't switch with the Edge monitor on the LBZ / LMM but for some reason I was thinking you could still switch with EFI v2 / v3
