Slowly but surely, Adam.
I'm only ~5 months (started Christmas weekend) into the project, gues it's not that bad.Slowly but surely, Adam.![]()
@1FastBrickWell the 2020- current L5P EOC are starting to trickle in so hopefully it won't be as much of an issue when your ready. I was able get everything from GM withen a week when I ordered mine a few weeks ago. Some places still show out of stock and I have heard from a few they were waiting on back orders. I didn't have any trouble though.
I went with the callies rods and reused my crank after keying it and having it magnafluxed. I went with the Mahle Race cast on mine. Defintly want to keep it under 700 on mine.@1FastBrick
I pulled it over to not clust up the thread..
l might just do the EOC upgrade when I put a new built short block in next year which would be the ovals from my hotshot LMM, entry level rods lml crank probably re-use, see if the old Hamilton cam is still good, maybe send it up to Eric at no limit and have him make a new one.
mains and head studs think that should live nice below 700hp
Crank and cam are keyed, has stock rods currently on that engine. So new rods means rebalance.I went with the callies rods and reused my crank after keying it and having it magnafluxed. I went with the Mahle Race cast on mine. Defintly want to keep it under 700 on mine.
Common drop in cam for non cut pistons 01-10 engines in summer of '16 from them.Is that a standard grind they offer?
I got the wagler stage1 standard pattern like Brad did when they were on sale for $300.Common drop in cam for non cut pistons 01-10 engines in summer of '16 from them.
Part number from them was "07-c-192/200" per my invoice.
IDK if it's these guysGood Evening, We have discontinued our duramax line. PowerStroke Products now offers them.
Thank you,
Hamilton Cams
powerstrokeproducts.com
www.dieselpowerproducts.com
www.duramaxdiesels.com
www.nolimitmfg.com
I was multitasking and didn't post fast enough ?You made me go look... here is the LMM one.
Camshaft Interchangable?
I have a wagler stg 1 here but am now ready to install it. Maybe next time Sent from my SM-G990U2 using Tapatalk Here is the specs. https://www.duramaxdiesels.com/forum/threads/can-someone-confirm-cam-lobe-order-for-me.89461/post-1210443 The peak valve lift is affected by rocker arm ratio...www.duramaxdiesels.com
