I recently have this issue as well. It will be much easier with no cab.Never need so long to remove an engine and transmission... but finally done
The installation will be made in the chassis without cabin and bed - much easier![]()
Today it was our last try. If it not had worked than we had remove the cab.I recently have this issue as well. It will be much easier with no cab.
The complete Truck will be rebuild, so brakelines also inside that issue. Thanks for the advice on Dorman BrakelineYou don't mess around.
Get the stainless Dorman brake line kit, its awesome.
I had drone issues on my truck, had to build a resonator tube before the muffler, worked like a charm. Also make it quieter but still has a nice tone when getting on it.
These trucks don't have lag so if you did, the turbo was probably faulty. Also replace the up pipes while you are in there.
Can't wait to see it finished.
Why can't you turbo the 6.2? Against the law? An HX40 works wonders, wakes them right up. I have an 84 van with a 6.2, built a remote mounted turbo kit, way more fun to drive and tow.
How do they know you put a 6.5 in vs the 6.2?
I had an HX35 on mine, with a Super40 compressor wheel, no lag but a bit too much emp, so I was going to put a 14cm housing on, then things changed. Will actually quieten up the exhaust,Yes i have heard about that issue there should be no lag - but i must confess, i didnt drive him before disambling. We just bring him home and start immediatly the check up.
It will not be notice as long you havent an accident or they notice for another reason like exhaust noise ...
Fact is no police officer will just see on the engine if it is 6.2 or 6.5
But if you have an accident and they check the complete Truck it can be very bad for you if you have a part on the truck which have no roadapproval. You lose the insurance and have to bear the entire damage in addition to perhaps criminal consequences in the case of personal injury.
It is no matter if you or the other is guilty in that accident. If they control the involved vehicles than you can be fast in such an issue.
Not sure what your rear gears are but mine are 3.08's, perfect for cruising.Add a turbo or a supercharger on the old block will be easier as they take the emissions of the original engine. So i have only to fullfill the demand on brake, suspension and frame. But the old block will not bear a lot of more HP. Max recommondated 220 HP also with girdle. Up on 280 HP the german roadapproval said it is ok in stock condition about 280 HP i need to improve the brake, suspension and frame with a very expensive roadapproval test
Thats why i hold any option open to improve the engine if we are not satisfy with the 180 HP he have now. He is build for tuning. Also the new transmission 4L80e is build up on a possible tuning - so that we are in a save way.
I dont want have again a damage just by driving the truck in the traffic. To enter highway we have here around 80-100 km/h to go in the line. The 40to truck usually goes with 80-90 kmg/h on highways allow is 80 km/h for them. So if you dont want to be an obstacle for others you drive minimum 90 km/h that brought the engine in the past always in the red zone by using highways daily about 30 km.
Result was cracked head, pistonrod bearings heat damage - but engine was still running ...
We dont go immideatly in that tuning as the Chevy will stay as oldtimer and not in daily use or as working truck.
Well we have 4.56 rear as this is the ratio of MSeries Pickups 4x4 and the TH400/Np208 combo. 4.10 is on the K5 / Blazer. In combination with original tires 235/80R16 ..... fate took its course. 25y ago we had not that knowledge like today about that engine. And dashboard is really empty no aditional gauges like watertemp. oiltemp. oilpress. or a speedometer. We had use aftermarket addtional Gauges in the past but dont use a speedometer.Not sure what your rear gears are but mine are 3.08's, perfect for cruising.
A turbo with the ip turned up wont' stress the engine, I was running 22 psi for years, but I also studded the heads, as the original 84 head gaskets didn't like some boost, lol.
These IDI engines crave boost.
I would think being a Military truck, its probably got 4:10's so yeah, not good for German highways.
The 4l80 will help tame some rpm as it probably has the 400, mine has the speed 700r4.
Keep up the good work, nice to see someone still doing stuff like this.![]()
